08-14-2022, 03:45 PM | #1 |
36 Ford brake pedal return spring
Any tips on replacing the spring? Where does it connect at the rear? Can you access the spring through the floor with the trans cover removed? Thanks!
Tim Carlig |
08-14-2022, 08:29 PM | #2 |
Re: 36 Ford brake pedal return spring
The rear of the brake pedal spring connects to a hole in the side of the tangs for the transmission mount. It’s the spring on the left in the picture. It is easy to get at with tranny cover removed. There is also a brake return spring on the brake rod cross shaft.
Wayne |
08-14-2022, 08:45 PM | #3 | |
08-14-2022, 09:11 PM | #4 |
Thanks Pete,
One of these days I’ll figure out making pics larger from my IPhone 👍 Wayne
Wayne |
08-15-2022, 01:29 PM | #5 |
I can’t see how this spring from C&G would work. I’ve been told the brake spring is the same as the clutch spring as shown in the above post. I removed the floor board and can get right at it. I ordered a clutch return spring.
Tim Carlig |
08-15-2022, 01:55 PM | #6 |
08-15-2022, 04:05 PM | #7 |
Dean,
That spring that you picture is the one that connects to the brake rod cross shaft. The V end hooks through a hole in the back of the frame tunnel and the hook connects between the two brake rods on top of the cross shaft. Wayne
Wayne |
08-15-2022, 07:19 PM | #8 |
wamnram, do you have a photo?
Tim Carlig |
08-15-2022, 07:27 PM | #9 |
The spring you are referring to hooks into the transmission mount
08-15-2022, 08:07 PM | #10 |
Freddie, which of the two are YOU referring to? I know the one I ordered, same as the clutch spring, connects as shown in post #3. It’s the one with the zig zag end I’m not sure of.
Tim Carlig |
08-15-2022, 08:12 PM | #11 |
That one goes below the tunnel, i had to replace that one on my 36 Coupe … zigzag end goes through the frame
08-15-2022, 08:14 PM | #12 |
It hooks directly onto the pin that connects the crossshaft to the brake rods
08-15-2022, 08:21 PM | #13 |
See picture upper left.
Wayne |
08-15-2022, 08:24 PM | #14 |
And that is what I have been telling him over on the EFV-8C web site. (it really goes through the X member of the frame -- not under it)
I tried to get a picture, but too late, as the drive shaft has been installed and you can not see it very well. I would have liked to see the size of the person that installed it back in 1936. His arms must have been the size of 8 by 8's. OR...........there was one of those special tools that did the job in 10 seconds or less as the frame moved down the assembly line. Last edited by nelsb01; 08-15-2022 at 08:42 PM. |
08-15-2022, 08:27 PM | #15 |
Thanks guys. The Green Bible only shows one spring, with the zig zag end. The spring that is the same as the clutch spring is easy to see, the one I ordered today.
Tim Carlig |
08-15-2022, 08:27 PM | #16 |
I just finished putting mine in using a pair of vise grips pulling on the hook end. Took everything I had to get it on the cross shaft!
Wayne |
08-15-2022, 08:31 PM | #17 |
Sorry for the confusion, yes the x member below the torque tube tunnel, I used an old body man pull hook
08-15-2022, 08:38 PM | #18 |
The picture in post 13….how is it oriented? The left of the picture is toward the rear of the car?? Viewed from the right side?
Tim Carlig |
08-15-2022, 08:41 PM | #19 |
Zigzag goes into the frame, pull the loop end over the pin
08-15-2022, 08:45 PM | #20 |
