06-13-2015, 05:13 PM | #1 |
Dash lights when I press the brake pedal
I have a 1937 Ford stock with 6 Volt system.
1st Problem: A few weeks ago I noticed that when I press the brake pedal the dash lights come on. If I turn off the dash light switch, the dash lights do not come on when I press the brake pedal. When I press the brake pedal I get no brake lights no matter what position the switch is in. No brake lights with headlight switch activated. So I get dash lights when I push the brake pedal. All my lights worked correctly in the past. Where would this be crossed up at? 2nd Problem: Today I installed a new dash/cowl harness. All went well with the install. When I started the car after installing the new dash harness I noticed that the ammeter is working backwards--when I floor it the needle goes negative. When I turn on the headlights, the needle goes positive. Exactly the opposite way that it should work. Any ideas as to why this would happen with the new dash harness? Is the yellow wire looped through the ammeter the wrong way? I still have the brake light/dash light problem after installing the new dash/cowl harness. Please help. All replies greatly appreciated. Thanks. TM |
06-13-2015, 05:16 PM | #2 |
Re: Dash lights when I press the brake pedal
Yes.......looped the wrong way thru ammeter........easy fix! DD
06-13-2015, 05:18 PM | #3 |
06-13-2015, 05:21 PM | #4 |
Tony, I'm tempted to make a joke here, but... The brake light switch and the dash light sources are switched, so just trace those back to sources and change them back.
Yes, the yellow wire needs to be disconnected and run through the ammeter loop in the opposite direction.
Alan |
06-13-2015, 05:34 PM | #5 | |
06-13-2015, 06:54 PM | #6 |
06-13-2015, 07:17 PM | #7 |
Sounds like brake lights are looking for a ground through dash lights. Pete
06-13-2015, 07:38 PM | #8 | |
I'll second that. Any time I have a strange acting electrical problem I look for a ground problem. I once had a suburban that when it was in reverse you could turn the key off and it would continue running. Turns out that the backup light was looking for ground and feeding the ignition. Strange but, true. |
06-13-2015, 08:59 PM | #9 | |
Alan |
06-13-2015, 09:02 PM | #10 |
Agree, I would just wire it straight from the fuse to the brake switch and skip the lighting switch. No need to skip the fuse.
06-13-2015, 10:41 PM | #11 | |
Alan and JSeery: Okay, So I can bypass the headlight switch body by connecting the green brake light wire to the hot side of the fuse block? And this might solve the problem and offer fuse protection to the circuit? I hope I am getting it. Should I try a new brake light switch anyways? The one I have is a modern repro. Will investigate on Sunday. Thanks guys. |
06-14-2015, 03:11 AM | #12 |
Tony, We might have a whole different animal here than we were thinking... Do you have mechanical brakes or hydraulic? The brake switch is different and it's late, my brain hurts already...
Alan |
06-14-2015, 03:41 AM | #13 |
Tony, You have a very simple problem of no ground on your rear tail lamp housings. This is a very common fault on even modern cars and trucks. As a quick test connect a jumper wire between the tail light metal body and a good ground like the bumper or chassis and recheck your stop and tail lights. I presume your 1937 ford has stock type rear lights. Do this test before you do any of the other alterations to wiring which have been suggested. Good luck, regards, Kevin.
06-14-2015, 01:10 PM | #14 |
Okay, I re-looped the ammeter wire and that problem is solved. Works perfectly.
Brake Light/Dash Light Problem: I connected the green wire to the hot side of the fuse and the brake light / dash light problem is still there. When I press the brake pedal, the dash lights come on. Could it be the switch itself? It is a modern repro. Alan, the brakes are stock Henry Ford Cables. Thanks to all who responded. Last edited by TonyM; 06-14-2015 at 01:17 PM. |
06-14-2015, 01:15 PM | #15 | |
One question: If the taillight housings need to be grounded now, how come the brake lights operated for three years with out being grounded? This problem with the brake lights was first noticed in late December when I put the car away for the winter. Tail lights work, always have, it is the brake light action that is the problem. If I ground the tail light housing to the frame and the problem persists, should I try a new brake light switch? Thanks to all who helped. Still trying to solve. |
06-14-2015, 01:25 PM | #16 | |
Take the tail light bulbs out and try it. It will tell you if it is the tail lights or not. Bill |
06-14-2015, 01:34 PM | #17 |
IF the taillights work, the brake light ground MOST-LIKELY is not the problem, as the taillights share the same (GROUNDED) bulbs, which work.
06-14-2015, 01:49 PM | #18 |
Is there a GREEN wire connected to BOTH sides of your BRAKE switch? If NOT green, what colors?
Since you can turn-off the INST LITE switch and the dash lites do not illuminate, there is nothing wrong with that switch. The brake lite switch also works properly, as moving it DOES turn something (dash lites) on. DD |
06-14-2015, 01:50 PM | #19 | |
Bill |
06-15-2015, 06:51 AM | #20 |
I would change the bulbs 1st. Used to run into that problem on 50's & 60's cars. Filament in the bulb shorts out and give you that result.
Dan Kingman Az. 86409 |
Thread Tools | |
Display Modes | |
