Old 11-10-2021, 05:39 PM   #1
Dennis Pereira
Dennis Pereira's Avatar
Default Electrolysis Tank
Working on a 7 tooth steering assembly heavy paint black / orange / yellow after a couple of hours paint is falling off . parts on the way so clean and get ready for paint . The bearings failed because of heavy waxy grease in box no lube getting to bearings .
Dennis in Kelsey ca
Dennis Pereira is offline   Reply With Quote
Old 11-10-2021, 08:44 PM   #2
Big hammer
Default Re: Electrolysis Tank
Looks like a well used tank! electrolysis I thought was for rust removal, must of had rust under the paint.
get a bigger hammer tap done
Old 11-10-2021, 08:48 PM   #3
old ugly
old ugly's Avatar
this will remove or loosen up paint, grease, dirt as well as rust.
a good way to clean up parts, just takes a bit of time to work.
i like using this method.
old ugly
my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want."
old ugly is offline   Reply With Quote
Old 11-10-2021, 11:45 PM   #4
Dennis Pereira
I use it to clean wheels also takes all the old paint off and rust a big box of arm @ Hammer washing soda in the mix .
Dennis in Kelsey ca
Old 11-11-2021, 07:44 AM   #5
bobbader
This is great and I know this stuff has been posted and talked about before, but, for the benefit of those who are seeing it for the first time “in all it’s glory”, a little explanation of how this is hooked up, how it functions, and what supplies to use would be much easier than going through the SEARCH process.
Thanks, Bob Bader
bobbader is offline   Reply With Quote
Old 11-11-2021, 09:14 AM   #6
rotorwrench
rotorwrench's Avatar
Electrolysis may remove some paints depending on the chemical composition of the paint but many paints have to be removed with a methylene chloride or acidic based strippers.
Corrosion can be removed by electrolysis or through acidic exposure of various mild forms of acid. Evapo-Rust uses chelation for oxide removal and is environmentally safe.
Electrolysis can have a negative effect on structural steels due to hydrogen embrittlement but it largely depends on what the use of the part is whether it may cause a problem.
Old 11-11-2021, 10:07 AM   #7
Kevin in NJ
My experience with electrolytic rust removal.
Some paints come off, some come off some and there is this red primer I run across that nothing wants to take off. Just a long time with sandblasting.
I found that a couple of days in a tank and you can cut sandblasting time on wheels in half or better. You mileage may vary depending paint, rust and such. I also do not have a tank large enough for a full wheel so I did half at a time so like 3 days or so per wheel.
I also found that you can get the rust that sticks the bolt in the bumper ends. Just put the end in the tank and let her go for a few days. Impossible suddenly frees up in no time.
FWIW, line of sight is less critical with ERR and if you get some carbon electrodes the parts come out cleaner.
Old 11-11-2021, 10:27 AM   #8
Bob C
Vince has some good information on his site.
http://www.fordgarage.com/pages/elec...cderusting.htm
Old 11-11-2021, 10:43 AM   #9
Dennis Pereira
I have 1 inch rebar hanging on the sides for anodes . I've cleaned Doors / wheels / splash shields / Hood sections / windshield frames / anything I can hang in the tank like Kevin said it speeds up sand blasting if needed . The arm and hammer washing soda also helps with oils and grease . You could do a whole frame in a swimming pool or a big hole lined with plastic lol . Also a good scrub brush and dish soap to remove slime rinse and back into the tank .
Dennis in Kelsey ca
Old 11-11-2021, 01:32 PM   #10
redmodelt
redmodelt's Avatar
Just don't use stainless-steel electrodes.
https://antique-engines.com/stainles...electrodes.htm
I have seen other reports that say the same thing.
Old 11-11-2021, 03:00 PM   #11
Dennis Pereira
Over night most of the paint and rust gone the ford black paint turns to slime and washes away . I'll let it go for a few more hours then metal prep to keep from flash rusting . Then rinse and scrub let dry and paint .
Dennis in Kelsey ca
Old 11-11-2021, 04:33 PM   #12
Synchro909
Synchro909's Avatar
Did you connect the steering column to the positive or the negative lead? I assume you used a battery charger for this.
Old 11-11-2021, 05:58 PM   #13
Dennis Pereira
Negative to the part positive to anodes / scrape steel I had the column hanging with string / suspended . Yes a battery charger for power supply .
Dennis in Kelsey ca
Old 11-11-2021, 06:02 PM   #14
Dennis Pereira
No rust under paint only where it was bare steel . When the black ford paint came off it was like new under the paint .
Dennis in Kelsey ca
Old 11-12-2021, 01:25 PM   #15
old ugly
old ugly's Avatar
this comes back to the old topic on which way the electrons travel.
negative towards the positive.
maybe H F was using his electrolysis tank when he built the model A?
old ugly
Old 11-12-2021, 02:07 PM   #16
Dennis Pereira
First coat of paint on steering column Por 15. And Deck Lid into the tank .
Dennis in Kelsey ca
