04-12-2017, 11:22 PM | #1 |
Oil Line Leak
Had the 52 Merc out for a short run this evening and when I parked it back indoors I noticed a new leak. The oil filter line where it attaches to the bell housing (sending unit?) was dripping from the line fitting. I'm hoping it just needs tightening but suspect it might need a new line. I might just see if I can get the local hydraulic shop to make one to fit.
https://www.youtube.com/user/roosty6/videos |
04-13-2017, 12:27 AM | #2 |
Re: Oil Line Leak
Or just take a copperline and a brake flare tool.
04-13-2017, 02:13 AM | #3 |
Re: Oil Line Leak
There is an idea I never considered. I don't know for sure what type ends are on the line yet. I have a flaring tool I could experiment with.
04-13-2017, 02:53 AM | #4 |
Re: Oil Line Leak
Normal doubleflare.
Just support long lines when made from copper or they can crack from vibration. |
04-13-2017, 04:11 AM | #5 |
Re: Oil Line Leak
This is obviously something that someone has improvised.
NAPA has a selection of 1/4" steel lines in various lengths with the fittings and flares installed. With the correct fittings installed on the block and filter it's just a matter of hand forming the tube to fit. Of course this is the option if tightening doesn't work.
04-13-2017, 06:40 AM | #6 |
Re: Oil Line Leak
the fitting going into the filter has a small orifice so only a small portion of the oil is filtered with the rest going through the engine.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
04-13-2017, 08:12 AM | #7 |
Re: Oil Line Leak
Pm sent
04-13-2017, 09:42 AM | #8 | |
Re: Oil Line Leak
04-13-2017, 10:41 AM | #9 |
Re: Oil Line Leak
The steel lines are exactly what I stated in my first post. 1/4" steel lines are original configuration.
04-13-2017, 10:56 AM | #10 |
Re: Oil Line Leak
From the parts book, EAB-6716-A oil filter inlet tube assy. 1/4" O.D. x approx.
12 7/16 overall length formed steel. Bob |
04-13-2017, 11:08 AM | #11 |
Re: Oil Line Leak
That is true but this system has been altered from stock with the oil pressure sender installed where the tube would normally go. The length would have to be determined from what currently exists.
04-13-2017, 01:12 PM | #12 |
Re: Oil Line Leak
New information. Both lines to the filter appear to be plain old gas line rubber hose with brass compression fittings each end. They have worked fine for decades but I guess the rubber has hardened and is ready for replacement. Looks like I need 21 inches overall for the top line. Have not removed the bottom line to the oil pan yet but I'm guessing it is time. I have a new piece of steel brake line (pre-flared) with a fitting that threads match so I'm still liking the brake line option. Or if I want to go cheap just some new rubber gas line and compression fittings.
04-13-2017, 01:53 PM | #13 | |
Re: Oil Line Leak
04-13-2017, 02:11 PM | #14 | |
Re: Oil Line Leak
Its curious why somebody replaced both original steel lines with these rubber replacements. I did not check but I assumed it is an original Ford filter system and not an add on aftermarket item.
04-13-2017, 02:22 PM | #15 |
Re: Oil Line Leak
I'm not sure which yours were originally, but some of the systems used the rubber style hoses.
04-13-2017, 02:41 PM | #16 | |
Re: Oil Line Leak
And later factory installed was all steel lines. I thought that as soon as there was a dedicated return into the oilpan there was steel lines only. |
04-13-2017, 02:43 PM | #17 |
Re: Oil Line Leak
Could be, like you stated, some of the early systems used hoses. At least the plumbing on Ralph's system does not look like original Ford. If the filter itself is after market or Ford I can't tell.
04-13-2017, 06:34 PM | #18 | |
Re: Oil Line Leak
I bought a length of steel brake line with flared fittings and am going to try and bend that into the shape I need. Nice thing about rubber lines is they are more forgiving when it comes to lining up the threads. I've seen steel lines into brass fittings stripped when somebody gets them cross threaded because there is not much give when it comes to alignment.
04-14-2017, 01:18 PM | #19 |
Re: Oil Line Leak
I see now why they went with rubber oil line from the filter on the 52 Merc. After struggling to try and bend a piece brake line into shape to replace it, I'm about ready to go back to the flexible line option. Got to get past the kickdown rod for the automatic, throttle linkage, fuel line. Its a challenge. Not giving up yet.
04-14-2017, 05:50 PM | #20 | |
Re: Oil Line Leak
