Old 08-06-2020, 07:10 PM   #1
Dale Dog
Default Clay Smith cam specs
Need help, looking for clay smith Flathead cam specs and grind numbers yours truly Ford barners.
Dale Dog is offline   Reply With Quote
Old 08-06-2020, 08:57 PM   #2
Tim Ayers
Default Re: Clay Smith cam specs
Hi Dale:
Do you have a Clay Smith grind in mind particularly? I have the specs for a 272-2 and 284-2.
Keep in mind almost all Clay Smith cams are fairly low lift when compared to their counterparts. Not saying they don't run well, just letting you know they are not high lift cams.
Old 08-06-2020, 10:11 PM   #3
flatjack9
flatjack9's Avatar
I also have specs on a 270X with .375 lift and a radius 454 with .400 lift.
Old 08-07-2020, 09:24 AM   #4
Dale Dog
Thanks for the reply Tim,What I'm doing is building a 39 block,my very first flattie and doing as much reaseach on different cams,I was really thinking of going with the L100 but thought to myself what specs did clay smith have on his cams but have struck out in finding any info,I mainly really what a mild cam, good for the street but just different from the norm that everyone uses. Any info on his cams and lifter combos would be great . Dale
Old 08-08-2020, 05:21 AM   #5
Tim Ayers
Dale,
Ah, got it. If you are set on running a Clay Smith cam, give them a ring and talk to them. It is a family run business and they'll be more than happy to talk to you about what they can offer.
Good luck.
Tim
Old 08-08-2020, 07:44 AM   #6
Dale Dog
Flatjack thank you for your reply also,that 270 cam is and sounds very interesting was there more than one variation of the 270,isky 1007 had a few variation? Dale
Old 08-08-2020, 08:43 AM   #7
flatjack9
flatjack9's Avatar
The 270 is listed as a race cam. Has a lot of overlap, so would not be a good candidate for a street cam.
Old 08-08-2020, 09:01 AM   #8
Dale Dog
So maybe the ones that Tim told me about is the cam of choice for the street ?
Old 08-08-2020, 10:18 AM   #9
JSeery
JSeery's Avatar
Quote from Pete on the HAMB:
"I get a big kick out of these discussions.
If people only knew.
Take 6 cams from the old days with SIMILAR SPECS and degree them.
They were all pirated from one cam grinder to another."
He would be a good person to talk with, my understanding is he can grind you about anything you want.
Old 08-08-2020, 03:17 PM   #10
Dale Dog
Thanks everyone,I will contact Clay's ,and now Pete by looks of it. Everyone stay safe. Dale Tytler Millbrook Ontario Canada
