Old 04-24-2014, 11:05 PM   #1
Popeye31
Popeye31's Avatar
Default changing clutch in a 36 1 ton
I have a 36 1 ton with v8 and 4 speed. is it faster to pull the motor or move the rear-end and cross member to change the clutch?
Live your dreams
Popeye31 is offline   Reply With Quote
Old 04-24-2014, 11:16 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: changing clutch in a 36 1 ton
Does it have a coupling in the middle of the driveshaft tube ---if so this can be dissconnected without removing the rear allowing trans removal
Old 04-25-2014, 06:40 AM   #3
Popeye31
Popeye31's Avatar
No it just has the rear end tube than a cross member than another tube and the cross member that bolts to the back of the trans.
Live your dreams
Old 04-25-2014, 06:51 AM   #4
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
It's a lot easier for me to pull the engine? Walt
Old 04-25-2014, 07:53 AM   #5
Kurt in NJ
Kurt in NJ's Avatar
Thats the coupling ---the short tube between the trans and the crossmember --a retainer is unbolted and the cover is slid back, and there is a bolted flange on the driveshaft u-joint so the shaft can be removed
To remove the flywheel the pan has to be dropped unless a later 2 piece pan has been installed
Which way is easiest probably depends on what tools you have --and what you are comfortable doing.
Old 04-25-2014, 12:52 PM   #6
Popeye31
Popeye31's Avatar
Well i pulled the motor will look for the retainer to when i go back together with it it will make it easier if i can take that middle shaft out.
Live your dreams
