04-24-2016, 03:53 PM | #1 |
Exhaust/intake manifold ?
Looks like I have a gasket leak on my exhaust manifold, and am wondering which is the best gasket material to use for the replacements.
Also, I do not find a recommendation for torqueing the manifold nuts, and should they be torqued with the manifold hot or cold? Thanks all, as usual Burt |
04-24-2016, 04:16 PM | #2 |
Re: Exhaust/intake manifold ?
I like the copper gasket and just snug the bolts, then check them again after a couple heat cycles.
04-24-2016, 04:29 PM | #3 |
Make sure you install the washers correctly or you'll break the manifold.
04-25-2016, 04:12 PM | #4 |
Mac's has two copper clad gasket sets, they are identical except one set has "glands" built into them. Is there a preference?
Thanks again burt |
04-25-2016, 05:35 PM | #5 |
The glands help, if your manifolds, particularly your exhaust, line up properly with the ports.
04-25-2016, 06:25 PM | #6 |
I will order up the gaskets and see how it goes. burt |
04-25-2016, 09:17 PM | #7 |
I put a TINY bead of high temp exhaust sealant around the bores on both sides of the copper gasket (NOT enough to "squirt" out)---I WON'T tell you how tight I torque them, 'cause everybody will ARGUE about it!
If you want to know, just PM me. Bill W.
"THE ASSISTANT GURU OF STUFF" Last edited by BILL WILLIAMSON; 04-26-2016 at 01:50 PM. |
