Old 07-22-2019, 11:29 AM   #1
48fordnut
48fordnut's Avatar
Question Fuel pump rod.
I have a situation. late block, 8cm, early cam 59a , intake 59a, fuel pump stand 59a.Which fuel pump rod do I use? I don't have either one.
thanks,
jim
48fordnut is offline   Reply With Quote
Old 07-22-2019, 11:46 AM   #2
Charlie ny
Default Re: Fuel pump rod.
The 8CM block has a larger diameter push rod bushing to accommodate the larger 8ba push rod. You can change the bushing to the early type (a risky task in many ways) or
use a modified 8BA push rod shortened to 8.875. I have these short 8bba push rods.
Yep, it happens all the time when mixing and matching.
Charlie ny
[email protected]
Charlie ny is offline   Reply With Quote
