02-21-2018, 06:47 PM | #1 |
1939 pickup firewall insulation
I've been stripping my cab of everything to prepare for paint. It had firewall insulation in it. Was this original to the vehicle or was this something added? Thanks
02-21-2018, 06:55 PM | #2 | |
Re: 1939 pickup firewall insulation
Is that what you'd removed?
02-22-2018, 12:37 AM | #3 |
Here is a piece of it.
02-22-2018, 05:23 AM | #4 |
That's what they came with , my 39 pkup had the same ,I believe my new one came from Carpenders . Sunshine
02-22-2018, 06:32 AM | #5 |
I got my one piece firewall insulator from Joes Antique part#75-700770-1 for 37-39 trucks. It is a thick molded ABS plastic textured panel that has the "chicken scratch" texture.
This one fit perfect in my cab but I did have to get the longer 7/8" insulator studs part# 48-7001670-A due to the thicker design. I also had to open up the holes through the insulator padding so the cab choke/throttle rods moved freely. As far as prepping for paint, tap all your floorboard screws and put some 1/4"-20 cheapo bolts in those holes before you begin, you won't have to remove primer/paint later. Last edited by 39portlander; 02-22-2018 at 06:44 AM. |
02-22-2018, 07:38 AM | #6 |
03-17-2018, 07:32 AM | #7 |
Hello, I am not finding an answer to a question That's most likely been asked. Does anyone make original type cardboard firewall pad not the ABS ??
03-17-2018, 08:56 AM | #8 |
Not that I am aware of.
03-17-2018, 09:11 AM | #9 |
