Old 05-31-2014, 04:51 PM   #1
mrtexas
mrtexas's Avatar
Default jig for painting spoked wheels
I have a hub ready:
I don't have a spare axle around. Can anyone post a picture about how to mount it to paint spoked wheels?
mrtexas is offline   Reply With Quote
Old 05-31-2014, 05:06 PM   #2
Clem Clement
Clem Clement's Avatar
Default Re: jig for painting spoked wheels
Mine is welded vertically to an axle housing.
Clem Clement is offline   Reply With Quote
Old 05-31-2014, 05:14 PM   #3
Krylon32
Last time I used your method I clamped it in a vise a covered the area with a drop cloth, but I was only doing 1 wheel. Friend of mine used an old spindle welded to a pipe and put it in an engine stand.
Krylon32 is offline   Reply With Quote
Old 05-31-2014, 06:50 PM   #4
john worden
john worden's Avatar
Clamp it to a saw horse. Spray one side, flip wheel and spray the other side.
I salvaged the turn table from beneath some junk recliners just for this purpose.
Louvering, bias ply tire-truing, metal shaping and forming, lathe and mill work, member shop HAGERTY Ins. expert repair network. High quality paint work in Iowa.
john worden is offline   Reply With Quote
Old 06-01-2014, 07:29 AM   #5
rich b
rich b's Avatar
Bolt it to an engine stand using the tie rod and drag link holes in the steering arm. The wheel ends up at decent height and the angle of wheel is easily adjusted; also the engine provides a secure and stable; but still portable base.
rich b is offline   Reply With Quote
Old 06-02-2014, 01:32 PM   #6
Turdytoo
Turdytoo's Avatar
Nine inch ford pickup axle works good.
Turdytoo is offline   Reply With Quote
Old 06-02-2014, 02:11 PM   #7
FlatheadTed
FlatheadTed's Avatar
bolt a 2x4 to it put it in through two wheels and tyres as a stand or bolt the 2x4 to a fence end ways .
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 06-02-2014, 10:08 PM   #8
34p-kup
I used 4 tubing spacers and long bolts thru plywood base to the backing plate holes with nuts. Sort of lazy susan. Conduit, carriage bolts, washers to keep conduit from digging into wood. Old backing plate for drill pattern.
34p-kup is offline   Reply With Quote
Old 06-03-2014, 08:57 AM   #9
whizzernick
whizzernick's Avatar
here is my fixture
whizzernick is offline   Reply With Quote
Old 06-03-2014, 04:14 PM   #10
tiger.1000
First time I've heard of anyone painting a wheel with a tyre on ? Is that how it's done over the pond ?
tiger.1000 is offline   Reply With Quote
Old 06-03-2014, 04:36 PM   #11
Andy
I cut a circle out of plywood that is the wheel center ID. I make another an inch bigger but cut the sides down so it will fit thru the center hole. I use an eye bolt to clamp them together. I hang them with some cord so I can spin them. I have had great results with this method. I made 5 sets of the hangers and do a set of wheels at a time.
Andy is offline   Reply With Quote
Old 06-16-2014, 06:32 PM   #12
hotcoupe
hotcoupe's Avatar
i meant to post this earlier. . . it cost me about $30.00 dollars total, you can paint just about any surface of the wheel and the wheel revolves @5 1/2 R.P.M.
tom
hotcoupe is offline   Reply With Quote
Old 06-16-2014, 06:33 PM   #13
hotcoupe
hotcoupe's Avatar
one more image.
Old 06-19-2014, 03:55 PM   #14
felix37
felix37's Avatar
HOTCOUPE, that is a neat set up. where did you get the motors, gears, etc..?
felix37 is offline   Reply With Quote
Old 06-19-2014, 05:45 PM   #15
texas webb
Yes,real nice.Where?
texas webb is offline   Reply With Quote
Old 06-19-2014, 07:50 PM   #16
jfcrash
jfcrash's Avatar
mrTexas,
Here a link to something I posted a couples years ago......
http://www.fordbarn.com/forum/showth...ng+wire+wheels
Jim
______________________________________________
jfc
I couldn't repair the brakes, so I adjusted the horn louder....
jfcrash is offline   Reply With Quote
Old 06-19-2014, 08:00 PM   #17
hotcoupe
hotcoupe's Avatar
felix 37 & texas webb, the motors were sourced at www.surpluscenter.com, the gears came from Amazon, the rollers are surplus urethane, the axles [shoulder bolts] and flanged bushings came from Grainger. the motors were the expensive part, i think they were $8.95 APIECE!
tom
Old 06-19-2014, 09:55 PM   #18
texas webb
hotcoupe,thank you,and surplus is a neat site!
