11-15-2021, 11:25 PM | #1 |
Carburetor passage way plugs
Does anyone have a diagram showing the location of the 4 passage way plus in a 1931 zenith carburetor?
11-16-2021, 06:49 AM | #2 |
Re: Carburetor passage way plugs
Look here: http://model-a.org/brass_passage_plugs.html
The site has diagrams of the passages in the top and bottom castings. Hope this helps.
11-16-2021, 07:28 AM | #3 |
Thanks!
11-16-2021, 07:38 AM | #4 |
If you remove the plugs,get some old split shot lead (fishing weight). Cut a piece off and plug the hole with it.
Works great. |
11-17-2021, 09:56 AM | #5 |
I used to have a really good one before my computer crashed and I lost everything, let me see if I can find it again...I'll have to have something to drink to do this
11-17-2021, 03:33 PM | #6 |
11-17-2021, 03:48 PM | #7 |
Try to clean the carburetor first without removing the plugs. I have done just that on the carburetor rebuilds I have done.
11-17-2021, 07:41 PM | #8 |
I received a carb that had some plugs already removed. I was just curious as to where the others were.
11-18-2021, 12:01 PM | #9 |
I've heard of people threading the holes and using set screws for plugs.
