Old 01-14-2024, 04:47 PM   #1
outsider347
Default Clutch,PP question
I have a 59AB, and I would like to update to a 10 " clutch
Will a 8ba fly wheel,,clutch, & PP fit under the AB bell housing properly?
I have a used 8BA flywheel, & PP that I mocked up, on it now. Looks to be OK
Any in operation issues?
Tis Gents.
outsider347 is offline   Reply With Quote
Old 01-14-2024, 04:59 PM   #2
Krylon32
Default Re: Clutch,PP question
No. The 59AB and 8BA flywheels are different and do not interchange. If your 59AB flywheel is not drilled to accept a 10 inch PP you may have to re drill it for the PP? I have used a 10 inch PP on the back for several 59AB motors.
Krylon32 is offline   Reply With Quote
Old 01-14-2024, 06:12 PM   #3
outsider347
Does the 8ba FW. & PP interfere inside the 59 bell housing?
Old 01-14-2024, 06:17 PM   #4
outsider347
Also
OK to turn some of the weight off of the 59 FW?
TKS
Old 01-14-2024, 06:59 PM   #5
Ken/Alabama
Ken/Alabama's Avatar
Originally Posted by outsider347 View Post
Also
TKS
Most 59A that I’ve worked on have a 10” clutch and the flywheel doesn’t have the large lip around the edge. Sounds like you might have an earlier flywheel. The 8BA flywheel will fit inside the bell housing but that’s not the problem, it has a different offset.
Ken/Alabama is offline   Reply With Quote
Old 01-14-2024, 07:21 PM   #6
petehoovie
petehoovie's Avatar
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 01-15-2024, 09:54 AM   #7
outsider347
How does that offset cause a problem?
Can the extra CI be turned of of the 59 FW
Tis
Old 01-15-2024, 10:03 AM   #8
Krylon32
Check around a 46-48 flywheel isn't that difficult to find. The machine shop I use has a pile of Flathead flywheels.
Old 01-15-2024, 10:15 AM   #9
cadillac512
cadillac512's Avatar
Tis
The offset causes starter drive gear to ring gear distance trouble. Some starters may work...I've heard of such but can't confirm that. Otherwise the parts will fit.
Going the opposite direction, a 59AB flywheel will usually contact the rear of the 8BA block.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 01-15-2024, 10:20 AM   #10
outsider347
I know that my engine is a 46-48
Could be a parts combo from the previous owners
I have a later merc block. Took me a couple days to air hammer the pistons out. This block is much, much worse condition. I did save the 4 " crank & FW (10 in clutch)
I thought that I could use this FW and get me to the 10 in clutch on my 59
The 59 FW has a large outer diameter of CI
If I use this FW, can I turn the extra CI off
Apologies about the rookie questions. I would really like to know
Old 01-15-2024, 11:34 AM   #11
cadillac512
Tis
Old 01-15-2024, 11:53 AM   #12
nickthebandit
Contact Charlie Schwendler in Orchard Park, 716-662-9159. He should be able to help you.
nickthebandit is offline   Reply With Quote
Old 01-16-2024, 06:00 PM   #13
38 coupe
38 coupe's Avatar
The factory 59 car and light truck engines all had 10" clutches in my experience. Are you sure you don't have a pre-war flywheel with a 9" clutch?
Old 01-17-2024, 10:13 AM   #14
outsider347
I think that you hit it .
My original clutch is 9 inches.
My FW is an early one. The PP mounting holes are blind bore holes, indicating pre war PP
Now I need a 10 in PP for 46-48 59 AB
Or I'm going to take a look at getting the PP from my 8 CM motor.
I understand that the problem is how the starter gear engages the ring gear
Anyone figured this out ???
Old 01-17-2024, 01:16 PM   #15
Kurt in NJ
Kurt in NJ's Avatar
I put a 46 big truck flywheel on a 49 merc, had to shave some off the back of the flywheel and make a custom starter drive to get full mesh with the ring gear that was a 11” clutch
Old 01-17-2024, 02:13 PM   #16
richard crow
send your pressure plate to a clutch rebuilder & ask them to put stronger springs in it it will hold as good as a 10
richard crow is offline   Reply With Quote
Old 01-17-2024, 04:28 PM   #17
Ken/Alabama
Isn’t the Mercury PP the Borg and Beck style. Might make a difference.
Old 01-18-2024, 02:34 PM   #18
Ol' Ron
Ol' Ron's Avatar
Money usually solves most problems. When you don't have any money, you learn allot. "Country smarts"
Old 01-18-2024, 05:54 PM   #19
outsider347
With ya Ron
When I get back out to my shop, I'm going to figure out how to make the 8 CM FW work.
Old 01-18-2024, 07:15 PM   #20
38 coupe
38 coupe's Avatar
Someone near you has to have a flywheel for a 10" pressure plate. I know I have several kicking around, but shipping from Texas to New York would be way more than the part is worth. If you have access to a lathe and a mill it is a simple job to turn off the lip and drill for the larger pressure plate bolt pattern.
Be careful with Borg&Beck style Mercury pressure plates, there are two of them and the later 52-53 doesn't work with the earlier throw out bearing.
