03-21-2020, 09:12 PM | #1 |
Exhaust Manifold bot holes
I discovered today that exhaust manifold bolt holes are stripped out. What have you all done to fix that? Drill and retap with 7/16?
Sent from my SM-G973U using Tapatalk |
03-21-2020, 09:14 PM | #2 |
Re: Exhaust Manifold bot holes
I should clarify, it's the ones into the block not the manifold itself.
03-21-2020, 09:52 PM | #3 |
What holes are you referring to? You are aware, aren't you, that the bolts in the front exhaust ports are already 7/16". (The others are 3/8".)
03-21-2020, 10:17 PM | #4 |
Thanks Tubman! No, I wasn't aware of that, or I guess I forgot since I tookit apart. That makes me feel better. Yeah, it is the front left side where I discovered it.
03-22-2020, 09:55 AM | #5 |
Sooo…..maybe if you try a 7/16" bolt instead of a 3/8", it may not feel like it's stripped? DD
03-22-2020, 11:41 AM | #6 |
03-22-2020, 12:30 PM | #7 |
Do not put to long a bolt in that hole as it is a blind hole and you can punch out the bottom in to the water jacket and get a leak Bolt 20420 S 7/16-14 X1 3/16 Ford made there own bolts so often not common sizes.
03-22-2020, 02:17 PM | #8 |
Ahhhhhh, that feels soooooo much better, nice tight fit. Of course I'm talking about the bolt, what were you thinking... LOL. So glad I don't have to worry about fixing threads. Thanks everyone for the help and tips on theboltsto get.
03-22-2020, 05:51 PM | #9 |
Two things a guy should remember about these old "boilers" : the front exhaust ports are 7/16" and that there is a #$@^$# bolt inside the water pump.
03-22-2020, 07:50 PM | #10 | |
…..and that #$@^$#bolt head has six points on it that are just achin' to be rounded-off! DD |
03-22-2020, 09:01 PM | #11 |
Use socket head cap screws and anti seize.
03-22-2020, 11:24 PM | #12 |
That's one solution to any future problems, once you figure-out how to get that #$@^$#bolt out that Henry installed seventy or eighty years ago on the first go-round. DD |
03-22-2020, 11:27 PM | #13 | |
wow! You had an original ORIGINAL Henry water pump fail on you?
Alan |
03-23-2020, 12:18 AM | #14 | |
Actually no, but I've certainly run into a nasty bolt or three while salvaging a block or two. DD |
