Old 03-03-2014, 09:51 PM   #1
bclement
bclement's Avatar
Default V-12
Ok, ok , I know......
I'm a dangerous novice flathead guy that jumped into V-12 'technology'.
Here' s what I got, what can you all tell me about it? I was thinking about putting it on the '38 engine.
Thanks
Brad
bclement is offline   Reply With Quote
Old 03-04-2014, 07:02 AM   #2
Vic Piano
Vic Piano's Avatar
Default Re: V-12
Brad, that is a rare intake manifold, as is most "speed equipment" for the Lincoln Zephyr/Continental HV-12. The '38 looks sweet. I'll have to take a ride down to see you one weekend, I'd also like to check out your '41 Continental Coupe. Vic
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 03-04-2014, 07:05 AM   #3
bclement
bclement's Avatar
Default Re: V-12
Vic,
Nothing like smelling oil fumes, old grease, and gas all the while looking at the beach!! But it would probably be more fun once I get the Continental back on the road!
Brad
Old 03-04-2014, 08:47 AM   #4
itsa52
itsa52's Avatar
Default Re: V-12
It looks like a "Hen's tooth" to me. Two of um on a V-12 should definitely help.
itsa52 is offline   Reply With Quote
Old 03-04-2014, 02:15 PM   #5
Ol' Ron
Ol' Ron's Avatar
Default Re: V-12
Very vintage, should work quite well when tuned right.
Old 03-04-2014, 03:51 PM   #6
hardtimes
hardtimes's Avatar
Default Re: V-12
Thanks
Brad
Hey Brad,
IMO, you are doing good to first check out the possibilities of good/bad/ugly of doing modification !
First Q, is what condition is your 12 in ? If 'rebuilt' ..I'd go for it ! If just running condition and history/internals not known...well is may be a crapshoot to ad to something unknown. For instance, I just took a 'rebuilt' 12 apart...and was darn glad that I did..whoa..nothing added on would have helped what I found. What's history of your 12.
Hey, if you like MORE, maybe you'd like this...
Bottom half of pic is three pot intake...
hardtimes is offline   Reply With Quote
Old 03-04-2014, 05:22 PM   #7
bclement
bclement's Avatar
Default Re: V-12
Yikes! I think three is a little much unless you are going to look at retuning internals. The 12 I have in the car is a good running unknown, the 38 'rebuilt' in the picture is a 'looks right and notionally known'. I got this intake and carburetors in a pile of other things that I just started going through.....interesting but I'm still learning.
Where did you get your copper head gaskets?
Old 03-04-2014, 10:21 PM   #8
hardtimes
hardtimes's Avatar
Default Re: V-12
Well, the old man that died had a ton of NOS parts. Most were removed prior to my arrival. But copper head gasket (one) was still available.
If you are running aluminum heads, I've been told/informed that it is a good idea to use composite head gaskets...not copper. PM sent to you.
Old 03-04-2014, 11:53 PM   #9
CBoz
CBoz's Avatar
Default Re: V-12
The stock intake as noted was for a single Stromberg carb with slightly bigger jets than the Ford. Frankly, Lincoln did that more for fuel efficiency than anything else. These cars really can benefit from two carbs. Three, not so sure...
CBoz is offline   Reply With Quote
Old 03-05-2014, 07:58 AM   #10
bclement
bclement's Avatar
Default Re: V-12
Everything everyone has mentioned so far makes perfect sense. As I'm still tweaking/tuning, getting the car into comfortable driving condition, now might not be the time to start messing with dual carbs. My car has neither overdrive or a Columbia rear end and as I've not really had the opportunity yet to really get her going down the road I can't say with certainty how 'good' or 'bad' things are in the current configuration.
Old 03-05-2014, 09:40 AM   #11
jkeesey
jkeesey's Avatar
Default Re: V-12
I have done extensive work on a Zephyr v12 with an Edmunds dual carb setup. My only word of advice is make sure your carb tuning is right. The guy that setup this Lincoln had too large of jets and the wrong power valves. I finally got my hands in it and made the old girl run like a top, but sadly too late as the previous tuning washed the cylinders and ruined the 3 year old rebuild.
jkeesey is offline   Reply With Quote
Old 03-05-2014, 09:59 AM   #12
bclement
bclement's Avatar
Default Re: V-12
Ok....some more research seems to indicate that the Edelbrock intake kept the front and rear carbs completely separate where the Edmunds did not? I assume this may be for the ease of adjustment/synch and not so much performance? Does that sound accurate?
Old 03-05-2014, 10:14 AM   #13
jkeesey
jkeesey's Avatar
Default Re: V-12
The Edmunds that I worked on were completely separate. Some "guru" drilled and added bypass lines underneath to equalize both sides which I had to remove. If I remember right, the one I service has original Zephyr carbs with 49 jets and 2.5 power valves. My memories a little fuzzy but I think that's it.
Old 03-05-2014, 10:25 AM   #14
Ol' Ron
Ol' Ron's Avatar
Default Re: V-12
This is a good example for the use of an A/F meter to aid in tuning. Don't forget to make sure the distributor is operating correctly.
Old 03-05-2014, 10:25 AM   #15
bclement
bclement's Avatar
Default Re: V-12
I checked and front and back are completely separate. It came of a '46 Lincoln coupe.....and was really about the only thing left worth taking off. It had Ford script 94 carbs on it and the linkage was a little 'home-made' looking so I'm real sure how it all worked. Also, the fuel pump and stem all seemed stock.
Feed back from the 'Hot Rod' world so far is that this isn't a speed part at all but a period aftermarket upgrade? I wasn't there in the40's so I don't know, but that doesn't seem to jive with what I thought I knew about Vic Edelbrock.
Old 03-05-2014, 11:09 AM   #16
jkeesey
jkeesey's Avatar
Default Re: V-12
Lincoln v12s aren't known for being monster race engines so the hot rod guys will steer away from them. They are cool in my book. The one I work on is a 40 so there may be a few differences.
