Old 12-16-2013, 10:37 PM   #1
Rustyspokes
Rustyspokes's Avatar
Default 1932 Rear Spring info
I need to replace my 1934 , 4 dr Ford ; rear spring ,I have a chance to get one from a 1932 Ford, will this work in my 34 , the length and leaf numbers , thanks guys ..
Rustyspokes is offline   Reply With Quote
Old 12-16-2013, 11:38 PM   #2
FlatheadTed
FlatheadTed's Avatar
Default Re: 1932 Rear Spring info
I would say yes
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 12-17-2013, 01:21 AM   #3
deuce_roadster
deuce_roadster's Avatar
If it has the same number of leaves you should be able to use it. I think any of the 32-34 curved springs will fit.
Old 12-17-2013, 09:37 AM   #4
32phil
Last year I replaced the rear spring in my 32 Fordor with a NOS unit. It had a 40-- part# on it. I looked it up in the "Green Bible" and it showed that # as a direct replacement part for my 1932 car.
Early Ford Lock & Key Service
http://www.fordbarn.com/forum/showthread.php?t=46583
32phil is offline   Reply With Quote
