07-13-2014, 07:54 PM | #1 |
Steering Adjustment
I had to remove the steering assembly from my late 31 CCPU to adjust the steering play which was in excess of 2 inches. It is a two tooth unit. I did all
the adjustments as as instructed in the Model A Ford mechanics Handbook Vol. 1. It mentions the centralization rivet slot is normally set in the vertical position. Question: What does the adjustment from the vertical position control? more info is needed so as to fine tune the steering assembly. Thanks for your welcome info. Grant |
