03-01-2019, 09:17 AM | #21 |
Re: removing head studs
I think Lawrie's method is great. A slight variation of the welded washer/nut combo. The key is to get enough heat down into the stud to break the thing loose. I think it is much easier to get the required heat with a welder rather than a torch but what the heck do I know.
I have also used the washer/nut method to get out those difficult door hinge bolts.
Do I look like I have a plan B? |
03-01-2019, 09:30 AM | #22 |
I have a friend that just burns them out with a torch, but not the blind ones.
03-01-2019, 09:52 AM | #23 | |
03-01-2019, 11:14 AM | #24 | |
Good luck Cheers Tony Also keep in mind that so often the reason the studs won’t come out is because of corrosion on the end in water jackets, this corrosion can also damage block threads as you wind them out |
03-01-2019, 12:14 PM | #25 |
Also keep in mind that so often the reason the studs won’t come out is because of corrosion on the end in water jackets, this corrosion can also damage block threads as you wind them out[/QUOTE]
Ah, great point. I did have one that did pull the bottom out of the pocket. |
03-01-2019, 05:19 PM | #26 |
