Old 08-06-2021, 07:53 AM   #1
excalibur
Default 1937 Flathead
I know this has been discussed earlier BUT, I have a 1937 flathead v8 in a 1941 pickup. The cylinder compression is 60 to 65 psi, dry in all of the cylinders. the oil pressure drops from 20 to 25 psi cold to 5 or less after it warms up. I need to rebuild it. Looking for a place that rebuilds flatheads in the Detroit area. Motor City flatheads does not exist to the best of my knowledge. Any info would be appreciated.
It might take me a while to get back to this site to check for replies so thank you all for your help in advance.
excalibur is offline   Reply With Quote
Old 08-06-2021, 07:57 AM   #2
Jack E/NJ
Jack E/NJ's Avatar
Default Re: 1937 Flathead
How's it run?
Jack E/NJ is offline   Reply With Quote
Old 08-06-2021, 02:01 PM   #3
excalibur
It runs ok but smokes a bit.
Old 08-06-2021, 02:22 PM   #4
CaliforniaBorn36
CaliforniaBorn36's Avatar
How much are you driving it? If it ain't broke, don't fix it. It could run for years as is. Once you open it up you don't know what you will find.
CaliforniaBorn36 is offline   Reply With Quote
Old 08-06-2021, 04:21 PM   #5
Jack E/NJ
Jack E/NJ's Avatar
>>>The cylinder compression is 60 to 65 psi, dry in all of the cylinders.>>>
How about giving one of them a few oil squirts to see what happens?
Old 08-07-2021, 05:25 AM   #6
Veeder
If you only drive it very rarely and it does not eliminate mosquitoes I vote drive it
Veeder is offline   Reply With Quote
Old 08-07-2021, 06:30 AM   #7
excalibur
The oil pressure is what scares me the most. I have valvoline VR1 20W50 oil in it now.
Old 08-07-2021, 07:35 AM   #8
Jack E/NJ
Jack E/NJ's Avatar
>>>the oil pressure drops from 20 to 25 psi cold to 5 or less after it warms up.>>>20W50>>>
Still not too bad even if using a mechanical guage.
Old 08-07-2021, 07:45 AM   #9
Kurt in NJ
Kurt in NJ's Avatar
In the service bulletins it lists "normal' oil pressure as 30 lbs at 2600 rpm
