02-24-2018, 12:01 PM | #1 |
NWC T5 Oil
Have a lot of conflicting answers on what is the correct oil. Does anyone know the answer?
02-24-2018, 12:07 PM | #2 |
Re: NWC T5 Oil
The world class switched to ATF because of the synchros, I believe the nwc would still use the original OEM recommendations. Any reason you don't what to follow the original reccomendations?
02-24-2018, 01:04 PM | #3 |
Re: NWC T5 Oil
I would like to follow the OEM recommendations but can't seem to find them. Ive looked all over the internet and tried contacting Tremec to no avail. Just wondering what other folks are using. I'm using Royal Purple Gear Max in it now but having trouble with leaks. It has a little over 3000 miles on it since rebuild.
02-24-2018, 04:41 PM | #4 |
Re: NWC T5 Oil
Well, what I'm seeing is Synchromesh 12345577. Think this stuff is expensive and hard to come by. Let me do some checking (I'm a World Class guy which uses Dextron III).
Update, from Flat Ernie post: All NWC T-5 use 70WT Gear Oil or Redline MTL. ALL WC T-5 use ATF. ALL subsequent manuals tell us to use ATF in ALL T-5. So, what's the story? The OEMs originally used a 70WT gear oil in the early NWC transmissions. As the automakers were focusing on NVH and MPG, the switch to ATF was made and this coincided with the WC upgrade. It is generally safe to use in the early T-5 as well. However, do NOT use gear oil in a WC T-5 though - it will ruin the blocker rings/synchros. Use a quality synthetic oil (regardless of which type you need to use) & change it frequently (every 15-20K). Fill to the fill plug; about 5-1/2 pints or 2-1/2 quarts. If you are having a leakage issue you are most likely going to have to find where it is leaking and fix it. Last edited by JSeery; 02-24-2018 at 04:51 PM. |
02-24-2018, 04:53 PM | #5 | |
Re: NWC T5 Oil
I switched to ATF synthetic years ago gave up on any of the recommended lubes especially when it required a GM only lube. So far after two cross country round trips and another 20,000 miles or so all is fine. As far as leaks changing to ATF will not eliminate that problem. Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
02-24-2018, 06:06 PM | #6 |
Re: NWC T5 Oil
Thanks for the responses. Much appreciated. |
02-24-2018, 06:16 PM | #7 |
Re: NWC T5 Oil
75W gear lube is in the viscosity range of 15W motor oil. Not what you want to hear, but don't think attempting to run a thicker lubricant is going to help. Bad news is you are going to have to fix the leaks. Who did the rebuild and why is it leaking? I have rebuilt a number of T5 and never had a leak issue, I would guess something is not correct somewhere.
02-24-2018, 07:04 PM | #8 | |
Re: NWC T5 Oil
02-24-2018, 09:11 PM | #9 |
Re: NWC T5 Oil
I have a non world class S-10 5 speed in my 40 and it uses ATF.
02-24-2018, 09:19 PM | #10 |
Re: NWC T5 Oil
i used Mobil 1 Synthetic ATF in my T-5s
02-24-2018, 11:45 PM | #11 |
Re: NWC T5 Oil
I've rebuilt a few T5's also and never had a leak.That is why it surprised me. It finally got warm enough to get out and crawl under it. My rear main doesn't leak so I suspected the tranny. Found the leak. It was the oil pressure sending unit. Easy fix. Thanks again for the help. Learned a little about oil viscosity.
02-25-2018, 12:11 AM | #12 |
Re: NWC T5 Oil
That's good! Easy fix.
