10-31-2017, 08:32 AM | #1 |
6v jumper pack
Well This past Sunday was a rainy day up here in the northeast. Never letting a day go by without accomplishing anything, I decided to build a jumper pack for 6Volt. I have four 6v cars and on occasion a 6v jump is needed. Also nice security when on the road is something goes wrong I can at least try to get to a safe port. Using a Optima 6 Volt battery (expensive) but worth the price in my view I get about ten years out of them. I built this box carrier, it's safe to carry around in you vehicle and give plenty of cranking amps for a jump start. Used some scrap plywood and a one " dowel. Found a can of red paint to top it off. I had a few old 12v packs so I cut off the wires and used two battery post connectors (cheap). I'm thinking to share this as it may be of interest to others. It took about one hour to put together. there is one screw holding the dowel in place should you desire to remove the battery. Just remove the screw push the dowel aside and you can just pop out the battery.
10-31-2017, 08:38 AM | #2 |
Re: 6v jumper pack
Ingenious
10-31-2017, 08:55 AM | #3 |
Re: 6v jumper pack
I like it.
10-31-2017, 09:54 AM | #4 |
Re: 6v jumper pack
Great idea. I like it, and the red paint is a perfect color for it.
Even the dowel ends to hold the clamps couldn't be improved on. |
10-31-2017, 10:43 AM | #5 |
Re: 6v jumper pack
That is sweet!
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
10-31-2017, 10:45 AM | #6 |
Re: 6v jumper pack
10-31-2017, 10:46 AM | #7 |
Re: 6v jumper pack
Great idea. Only one thing concerns me though...Secure it well when transporting so it will not tip over when in the car. The two post clamps could short against the metal of the car. You have enough current there to create a pretty good DC arc welder.
Good Day! |
10-31-2017, 10:48 AM | #8 |
Re: 6v jumper pack
For those of you that are not acquainted with the Optima spiral wound battery, they can be laid down , upside down, or right side up, they are sealed and don't require any special orientation.
10-31-2017, 10:50 AM | #9 |
Re: 6v jumper pack
You could always put a top over the battery, if this concerns you.
10-31-2017, 11:36 AM | #10 |
Re: 6v jumper pack
I wonder if an Optima would fit in a Harbor Freight .50 Caliber plastic Ammo Box?
THAT would be even easier for those of us who are not woodsmiths. Keep the jumpers separate. UPDATE IXNAY on the HF .50 cal box OPTIMA 6V is 9.9"X3.4"X7.8" .50 cal HF METAL Ammo Box is 11 .1"X5.5"X6.9" Last edited by Bruce Adams; 10-31-2017 at 11:46 AM. |
10-31-2017, 11:53 AM | #11 |
Re: 6v jumper pack
Very good idea.....well thought out. How long are the cables? My only other thought is you can but a fairly decent portable battery jumper for around 100.00 and a cheepe for around 60 or 70 that has a light and a mini compressor. None the less, I appreciate the thought and the time put into the one you made. Thanks for sharing.
10-31-2017, 12:32 PM | #12 |
Re: 6v jumper pack
That's great. Just a short time ago I searched for a commercially available 6v jump pack. The only one I could find was only available and Europe and crazy expensive...even before the shipping charge.
The only thing that I might add is some sort of disconnect or shut off switch. Thanks for sharing. Ken
Style beats speed any day, and with a lot fewer tickets. |
10-31-2017, 12:45 PM | #13 | |
Re: 6v jumper pack
10-31-2017, 12:45 PM | #14 |
Re: 6v jumper pack
Chief tole me that ELECTRICITY wuz BLUE??????
Bill Confused
10-31-2017, 01:15 PM | #15 | |
Re: 6v jumper pack
The one Frank made is much better, and it's 6 volts. |
10-31-2017, 04:23 PM | #16 |
Re: 6v jumper pack
My mistake. Every old car I ever owned I converted to 12V negative ground so I had 12V on the brain. I forgot a lot of guys keep the 6V system. Although, I never had a problem running the starter on 12V including the three As I have now.
10-31-2017, 07:46 PM | #17 |
Re: 6v jumper pack
Great Idea, just a thought...I would add a battery tender lead to the battery... Easy charging and it would always be ready to go....
11-01-2017, 09:31 AM | #18 |
Re: 6v jumper pack
FRANK's got a good idea and the only improvement that it needs is maybe a disconnect switch of some kind.
11-01-2017, 10:31 AM | #19 |
Re: 6v jumper pack
Original:
11-01-2017, 10:37 AM | #20 | ||
Re: 6v jumper pack
Thread Tools | |
Display Modes | |
