Old 05-11-2015, 04:23 PM   #1
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
Default Vacuum line UPDATE & REPAIR
I seem to have lost my vacuum on my 160c and I think it might be in the hose, trouble is the last person routed the hose line BEHIND the header, wondering if anyone has a pic of the route of the vacuum line that goes up the window channel and hose route.
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 05-11-2015, 06:33 PM   #2
Charles Coe
Charles Coe's Avatar
Default Re: Vacuum line picture needed for SW Fordor location
That's the way mine is routed. The steel tube runs over and then 90 degrees back into the car with the hose just from there to the wiper. I can post a picture without the trim piece in place if that would be helpful.
Charles Coe is offline   Reply With Quote
Old 05-11-2015, 07:00 PM   #3
msmaron
msmaron's Avatar
Into the car?? What do you mean? And yes post a picture please.
Mark Maron
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 05-11-2015, 07:52 PM   #4
Charles Coe
Mark, the steel line runs in the channel of the trim piece and then 90 degrees through a hole in the trim which is just over 27 inches from the passenger side end. The only place there is hose is inside the car from the end of the steel line a few inches to the wiper and from the other end to the fitting through the firewall. Here's a picture from the interior:
Old 05-12-2015, 12:09 PM   #5
Mitch//pa
Mark whats your problem? did you lose vacuum to the wiper?
if so did you try to isolate where the problem might be first..what did you do to determine the problem is in the pillar tube?
Old 05-12-2015, 12:14 PM   #6
msmaron
msmaron's Avatar
Mitch, been working on isolating it, manifold to outside line great vacuum. Hose to wiper DEAD.. My assumption is of course either the hose or the line from the 90 degree turn...However it is routed inside the trim and cannot get to it without dropping the windshield and removing the the trim plate to the header. My thought is that line should NOT be behind the trim plate but in front and the hose routes along the windshield line and then INTO the header and comes out inside to the wiper.
Mark Maron
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 05-12-2015, 12:17 PM   #7
Mitch//pa
Mark
did you unscrew the steel line inside the car at the firewall and ck for vacuum in the passenger compartment?
Old 05-12-2015, 12:18 PM   #8
msmaron
msmaron's Avatar
Yes mitch, and at the connection I do have it... but also at the insert on the outside firewall i have really good vacuum.
Mark Maron
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 05-12-2015, 12:23 PM   #9
Mitch//pa
can you disconnect the vacuum hose at the top of the pillar tube and check it there?
Old 05-12-2015, 12:25 PM   #10
msmaron
msmaron's Avatar
That is the issue Mitch...That is what i think is WRONG and it is behind the header plate, Take a look at my pic I posted and you see it goes behind. If i was able to get to it I would change the hose and be done and test..
Mark Maron
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 05-12-2015, 12:38 PM   #11
msmaron
msmaron's Avatar
Just found these original pics of the routing of the pipe,. a MUCH longer pipe than the 36 inch one they sell today!!
Mark Maron
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 05-12-2015, 12:50 PM   #12
Marco Tahtaras
Marco Tahtaras's Avatar
What Charles showed is not only correct, but appears to be the original. All the slant windshield models used that line. the fabric (not rubber) tube that connects the wiper to the steel tube is only 3-3/4" long.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 05-12-2015, 01:06 PM   #13
msmaron
msmaron's Avatar
Yes assumed that from my pics also Marco,.and appreciate it greatly. That is one hard line to find for sure...BUT are you also saying that it DOES go behind/under the header trim???
Mark Maron
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 05-12-2015, 02:04 PM   #14
Mitch//pa
did you try blowing air through the tube
Old 05-12-2015, 02:31 PM   #15
msmaron
msmaron's Avatar
Not yet but I will for sure, I do know based on the amount of TUBE inside there (rubber( I do not have an original vacuum line., SO the question now is do I run a NEW rubber line on the outside of the header or on the inside??
Mark Maron
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 05-12-2015, 03:07 PM   #16
Marco Tahtaras
It's done exactly like your photo shows.
Old 05-12-2015, 03:08 PM   #17
msmaron
msmaron's Avatar
Perfect outside of header, thank you and thank everyone for assistance, Now have to modify with the new lines manufactured.
Mark Maron
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 05-12-2015, 05:00 PM   #18
Charles Coe
Best I can measure, mine is about 51 inches long.
Old 05-30-2015, 11:27 AM   #19
msmaron
msmaron's Avatar
Default Re: Vacuum line REPAIRED!!! on SW
Repaired and works great. Ran a new vacuum line across the header plate from the original line up the stantion., and into the wiper hold,. added approx 3" rubber hose and working fantastic now. Thank you again everyone who helped!
Mark Maron
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 11-14-2015, 09:00 AM   #20
Pilotdave
Pilotdave's Avatar
I'm working on a similar situation for my A-400. I'm curious about how the vacuum line that routes down through the stantion connects to the firewall inside the car. Charles Coe refers to a hose that connects from the end of the steel line to the firewall - can someone post a photo of that hose showing both ends?
Also, I'm suspecting that I will need to fabricate the steel line - does anyone know a source for it?
Thanks very much.
Dave
Pilotdave is offline   Reply With Quote
