03-26-2015, 06:30 PM | #1 |
How is heater cover attached?
How is the manifold heater, for the stock manifold attached? Doe you just push it down? Seems like it would rattle. What am I missing?
Tim |
03-26-2015, 06:50 PM | #2 |
Re: How is heater cover attached?
There should be 2) holes in the top surface. There should be 2) 1/4"-20 screws, that hold it firmly to the top of the manifold.
03-26-2015, 07:47 PM | #3 |
No, This is the heater cover that goes on the standard exhaust. Not the speasal heater manifold.
03-27-2015, 05:32 AM | #4 |
That one is junk. It goes on with 1/4-20 clamp bolts that hook under the manifold and never work.
03-27-2015, 07:11 AM | #5 |
I'd like to have one of these.
03-27-2015, 07:44 AM | #6 |
'31 40B '31 68C |
03-27-2015, 07:59 AM | #7 |
If you are referring to this type.... I chucked the bolt that never worked and just put on two stainless hose clamps. (sorry... iphone photo and forum does not read orientation code... )
Worked all winter. |
03-27-2015, 11:17 AM | #8 |
Made a clamp from head bolt to nib on heater with spring between. Works great! Tim
03-28-2015, 10:10 PM | #9 |
Here is an even better tin heater cover than the one I posted in #5. This one doesn't cut the firewall, but comes up through the wood floorboard.
03-28-2015, 10:22 PM | #10 |
Fiddlybits picture
03-29-2015, 09:03 AM | #11 |
I use new baling wire every fall.
03-29-2015, 03:52 PM | #12 |
Thanks for the flip Afordman31.
normally post from desktop and can flip me but posted from phone. |
04-01-2015, 03:07 PM | #13 |
Two large hose clamps work perfectly for me.
04-01-2015, 03:36 PM | #14 |
I ended up making a clamp with a spring and using the head bolt.
04-01-2015, 04:39 PM | #15 | |
Being a Colorado car, they probably tried everything they could. How do I rotate pix?
'29 standard coupe project build thread Last edited by DadOfTwo; 04-01-2015 at 05:00 PM. |
04-01-2015, 08:06 PM | #16 |
For someone that claims to be knowledgeable in the trade, that is a pretty ignorant statement. I and many others have them and they work well.
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
