Old 02-24-2018, 01:55 PM   #1
JohnB15632
JohnB15632's Avatar
Default 31 S/W 4D TS Rear Window
On a 31 SW TS, are there any window garnishings that go around the rear window?
Is there any items that finish off the rear window as finish the door windows?
Thanks,
Disregard this post. I found the metal frame that goes around the window.
Sorry
JohnB15632 is offline   Reply With Quote
Old 02-24-2018, 03:15 PM   #2
duke36
Default Re: 31 S/W 4D TS Rear Window
Yes; just one single frame with oval head slotted wood screws. The SW was had with a rear window shade/pull tab. See photo in the judging stds.
Old 02-24-2018, 04:22 PM   #3
burner31
burner31's Avatar
Other then the frame no other garnish that I know of.
Your rear window looks very familiar, in fact looks just like mine, insulation and all, but with one small differance.
Your dome light wiring seems to be routed towards the drivers side, have mine going towards the passender side,
Keith
Shawnee OK
'31 SW 160-B
Old 02-25-2018, 12:11 PM   #4
JohnB15632
JohnB15632's Avatar
What you see in the picture is the ground wire for the dome light. The power wire goes down the passenger side.
Thanks,
Old 02-25-2018, 12:39 PM   #5
burner31
burner31's Avatar
Thanks,
OK, I grounded mine near the light on the body
Keith
Shawnee OK
'31 SW 160-B
Old 02-26-2018, 12:52 PM   #6
JohnB15632
JohnB15632's Avatar
Does anyone know if the 31 Town Sedan came with a garnish strip below the rear window?
I saw a picture of one once, but I can not find that picture. It was the only I have seen so far with the same garnish that is used on the side windows, that is used on the rear window.
Thanks,
Old 02-27-2018, 08:06 AM   #7
Craggles
Craggles's Avatar
This is a pic of mine. I can’t be sure how correct it is as not everything on the car is correct, maybe others can help with that.
Craggles is offline   Reply With Quote
