02-14-2016, 12:02 AM | #21 |
Re: ford speedster
Great looking car! Somebody mentioned similarity to '39 Bentley, and I see that, but I also see a little bit of three wheel Morgan in it too (might just be me).
02-14-2016, 06:20 AM | #22 |
Re: ford speedster
Marvin, its an ash frame clad in aluminium NO FIBRE!The chassis has been lowered by 4” and has extended front dum irons. It has also been modified to a longer wheel base. Model A Engine fitted with a Model B crank shaft
* Line bored shell bearings conversion to rods and mains * Cross drilled crank shaft * Lightened flywheel * Fully balanced * Mild camshaft *Aluminium Cylinder head fitted – I.O.E type with 2” inlet valves * Fully adjustable oil pressure relief * Twin SU carbs * 4 Branch balanced exhaust manifolds * 2 ½” Exhaust System * Mag Ignition |
02-14-2016, 06:22 AM | #23 |
Re: ford speedster
@ Glenn Very Nice station wagon, I love them.
02-14-2016, 07:47 AM | #24 | |
Re: ford speedster
An IOE cylinder head ! Would sure like to see a picture of that and know who made it. Thats neat. |
02-14-2016, 08:13 AM | #25 |
Re: ford speedster
02-14-2016, 11:46 AM | #26 |
Re: ford speedster
02-14-2016, 11:56 AM | #27 |
Re: ford speedster
02-14-2016, 12:02 PM | #28 |
Re: ford speedster
Sadly, I am unable to claim the credit for the work. I have taken a body that needed finishing, and improved the aesthetics, the engine was also there in its converted form but sadly needed a lot of work to 'finish' it. The teething troubles turned into many pounds worth of restitutions that should have been easy fixes when created. I experienced a tremendous learning curve but ultimately have a much better grasp of Model A's.
02-14-2016, 12:06 PM | #29 |
Re: ford speedster
Thanks Juggs, (wish I had given it a clean first!) and thanks for the info on my woodie.
02-14-2016, 03:27 PM | #30 |
Re: ford speedster
02-14-2016, 03:51 PM | #31 |
Re: ford speedster
I think they (Belcher Engineering in UK) only made 6 of them. I know the whereabouts of 3 running in cars and another (maybe) still under a bed, but the others who knows?
Combustion chambers modelled on McKee (sp?) heads which again are pretty rare |
02-15-2016, 02:52 PM | #32 |
Re: ford speedster
Left hand drive must make life so much easier!
For us RHDers we have the exhaust and the steering box on the same side. It one wants to retain the original steering and light switch, free flow exhausts are a problem unless you poke the straight out the side of the bonnet(Hood?) It looks so simple in the photo. Keith Last edited by wensum; 02-16-2016 at 02:32 PM. |
02-26-2016, 11:10 PM | #33 |
Re: ford speedster
Very nice Speedster. Does it currently have the mudguards attached? If so I would love to see a picture of the mounts for them. Thank you in advance.
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain. It is the very things that we think we know, that keep us from learning what we should know.- Unknown |
02-28-2016, 04:28 AM | #34 |
Re: ford speedster
Hi, yes they are attached, i had them fabricated, then the brackets are welded to the back on the brake drum so the turn with the wheel.
02-28-2016, 08:08 AM | #35 |
Re: ford speedster
NOW that's a speedster. Excellent . Tony
03-12-2016, 04:45 AM | #36 |
Re: ford speedster
Here is a 1.16 million (pound?) version, before the insurance bill ...
http://pursuitist.com/rare-bentley-w...s-up-for-sale/ |
