Old 02-05-2020, 07:09 PM   #21
Fhane
Fhane's Avatar
Default Re: loping engine?
Two things may help
Google loping engine.
Run a test with a vacuum gauge if possible.
Fhane is offline   Reply With Quote
Old 02-05-2020, 09:19 PM   #22
Purdy Swoft
Purdy Swoft's Avatar
I always replace the adjusting needle $4.95 and the needle adjustment housing $8.00 on all of my Zenith one and two , plus Tillotson model X and FX carburetors . these parts are listed on page 64 of Bratton's Catalog . These are the parts that connect to the choke rod and adjusts rich and lean for the GAV , gas adjusting valve on the carburetor . Because of regular adjustment the needle can wear and cause rich operation .
Old 02-06-2020, 08:00 PM   #23
marty in Ohio
marty in Ohio's Avatar
Rebuilt the carb. Now back in business
marty in Ohio is offline   Reply With Quote
Old 02-29-2020, 07:42 PM   #24
Gene F
Gene F's Avatar
Yes, and check the carb is not loose. Don't overtighten it! Some times the simplest things will get ya.,
Gene F is offline   Reply With Quote
