10-11-2016, 09:05 PM | #1 |
Leave engine/radiator empty?
So heres a question and situation:
Situation is I got my AA frame running beautifully (video to come) since I replaced all bearings in the trans (no more thudding/clacking) and cleaned up the teeth. No weird noises and smooth as warm butter driving it. I also while it was down I installed an oversize throttle shaft due to some wear on mine and couldnt get it to idle the nice model a pakita packita packita and flushed the block and radiator out so it doesnt overheat anymore. Now I start on the body work and finding some ever critical parts so the frame sits. I just put pure water in it for testing purposes (much easier to dump out if I had another problem). I plan to drain all water out so no fear of freezing. But here is the question: Should I leave it bone empty till next spring? OR Should I fill with 50/50 antifreeze? I have been advised to fill with antifreeze (green stuff) even if the engine just sits - cant rust that way. Also a side question : any tricks to get the dang ford repo hose clamps to seal?
1929 Model AA - Need long splash aprons! |
10-11-2016, 09:28 PM | #2 |
Re: Leave engine/radiator empty?
50/50 to prevent rust
10-11-2016, 09:35 PM | #3 |
Yes. Replace them with modern hose clamps. After a while, the hoses will fit so tight, you won't even need hose clamps anymore. At which time, you can reinstall the repro hose clamps.
10-11-2016, 09:44 PM | #4 |
10-11-2016, 10:21 PM | #5 |
If you run it with plain water add a can of water pump lubricant to the water to stop corrosion and lube the water pump. I would use antifreeze and not drain it at all. If you use distilled water in place of tap or well water your should be able to leave the antifreeze in for a couple of years.
10-11-2016, 11:20 PM | #6 |
For quite a few years Prestone Antifreeze Concentrate has advertised recommending changing their Prestone antifreeze every 5 years ...... or every 150,000 miles ...... nothing like a win-win protection. For years, distilled or rain water was recommended for all vintage radiators because neither will leave harmful mineral deposits therin. Also, often heard people who only drink pure rain water have far less possibilities of developing kidney stones ..... but, most people never listen ..... they pour well water in their Model A radiators and wonder why their Model A cooling systems develop mineral type kidney stones. LOL Last edited by H. L. Chauvin; 10-11-2016 at 11:21 PM. Reason: typo |
10-11-2016, 11:28 PM | #7 |
yea we live about 1-2 blocks from the towns water treatment plant so our water doesnt need a water softner.
Alright sounds like 50/50 it is. Farm store has the green stuff concentrate on sale for $9 a gallon.
10-12-2016, 12:01 AM | #8 |
make sure you are buying full anti-freeze not the 50/50 mix.
10-12-2016, 12:31 AM | #9 |
Agree .... buying 50/50 mix antifreeze makes about as much sense as going to a local expensive bar to buy mixed drinks to bring to a family Christmas Party.
10-12-2016, 10:34 AM | #10 |
Re-torque the head first.
10-12-2016, 11:13 AM | #11 |
Why do people use a premixed 50/50? Isn't cheaper to purchase straight antifreeze and mix it with distilled water yourself
31 Tudor 66 Bonneville 57 Chevy pickup 27 T roadster pick up |
10-12-2016, 12:11 PM | #12 |
Hi John,
Maybe same reason so many buy already prepared quickly fixed canned biscuits. Some have lead in their drinking water ...... some slowly develop lead elsewhere. Looks like at the rate we appear to be headed, maybe "everybody" will soon be demanding battery operated shopping carts at Wal-Mart. |
10-12-2016, 12:14 PM | #13 | |
By the time you buy straight antifreeze, and then buy distilled water, the difference in price isn't all that great. YMMV
10-12-2016, 01:24 PM | #14 |
Buy 2 Gallons of anti-freeze concentrate and 2 Gallons of distilled water. Put one gallon of antifreeze, then one gallon of water in the radiator. Now add about half of your second gallon of antifreeze to your radiator. Then top off your radiator with second gallon of water. Now fill the half empty jug of antifreeze with the remaining water. Run the engine to mix it up. While the engine's warming up, recycle the three extra plastic bottles and put your "premixed" gallon aside for topping off the system as needed. I also write the date I mixed it on the jug, I don't know if it goes bad but after a year I figure it's toast. On hot days I top the radiator for good measure, the extra gallon lasts me about a year. Also that extra gallon has saved friends and strangers alike over the years. I keep it in the trunk of my car.
Blackwall Panthers Nor Cal chapter |
10-12-2016, 01:31 PM | #15 |
Yea I can see myself using full strength at the shop with distilled water. Lol... NOT....
50/50 in 55 gal drums is CHEEP... |
10-12-2016, 02:27 PM | #16 |
What is the cooling system capacity for an A? i was going to buy several gallons of it to do my modern anyways.
10-12-2016, 03:00 PM | #17 |
Full capacity is 3 gallons, so you should use more than 2 1/2 gallons. I usually use a gallon of water and 1 1/2 gallons of antifreeze.
10-12-2016, 03:34 PM | #18 |
I find that moonshine gets me through the winter....and the car too.. ;-)
10-12-2016, 04:15 PM | #19 | ||
Hey Brother I already answered this for you.
Good Luck Quote:
10-12-2016, 04:30 PM | #20 | |
http://MODELABASICS.com/ How Things Work on a Model "A" Ford Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles. |
