12-28-2015, 09:15 PM | #1 |
Should I Remove Head Nuts? Rish Damage?
Gents,
I want to pose this dilemma- I have my engine ready for paint but I am thinking about of changing the head gasket. I tried to remove the first stud-nut and that sucker won't budge! I don't want to risk snapping it- so what would you do? The car runs great, has at least 85K on the engine. if not more, but should I risk ripping into it? Are the stud nuts normally frozen and how easy is it to break off a stud? This is my first A but have done many T's. Thanks in advance, Jim
"Whether you think you can, or think you can't- you're right." H. Ford |
12-28-2015, 09:30 PM | #2 |
Re: Should I Remove Head Nuts? Rish Damage?
If there is nothing wrong, STOP! Leave it alone.
You say it runs great. Head studs have a habit of breaking when stubborn. If you just need something to do, watch soap operas....lol |
12-28-2015, 09:36 PM | #3 |
X2
If it ain't broke-Don't fix it! |
12-28-2015, 10:54 PM | #4 |
I agree to leave it alone.
Actually with 85,000 miles it may have already had one or two engine overhauls or rebuilds. Count your blessings that you have a good running engine. |
12-28-2015, 11:05 PM | #5 |
Hallelujah- that's some great advice and I'll smoke a cigar instead!
Thanks guys! Jim
"Whether you think you can, or think you can't- you're right." H. Ford Last edited by jchochole; 12-28-2015 at 11:06 PM. Reason: spelled hallelujah wrong |
12-28-2015, 11:13 PM | #6 |
If you want, take a wire wheel and run it along the gasket edge to clean it up. You can then use pin striping tape and mask off the gasket edge to keep the engine paint off the cleaned edge. Same with the nuts, brush and tape off, then paint.
12-28-2015, 11:16 PM | #7 |
I have no clue why you would want to change head gaskets, but if you want some assurance its good, perform a compression test as described in "Model A Mechanics Handbook" by Les Andrews, available at the usual vendors and MAFCA and MARC Model A Clubs.
12-28-2015, 11:17 PM | #8 |
If it runs great, enjoy it....don't mess with it! Wayne
12-28-2015, 11:49 PM | #9 |
Aw.. Come on.. Latest is now,
"If it ain't broke, fix it till it's." Done that a few times. Have you? Larry
Good enough.. Isn't. |
12-29-2015, 12:40 AM | #10 |
Must have been built mid week, on a beautiful day. I've had some motors in the past that were probably built on a friday afternoon when the guys were trying to leave!
12-29-2015, 01:39 AM | #11 |
After you paint, oil the nuts with light oil or penetrating oil, and then light oil. Then when you do have to change your gasket it might let you get the nuts loose without breaking things
12-29-2015, 08:20 AM | #12 |
Enjoy the cigar and leave your engine alone. If you still want to paint, carefully mask ALL areas and pieces not to be painted. Smoke one for me, I quit many years ago and still get an urge for a wood tip once in awhile. jiml...
12-29-2015, 01:59 PM | #13 |
I thought that if it doesn't move, FORCE IT, if it breaks then it needed to be replaced anyway!
MY PROBLEM CHILD! |
12-29-2015, 02:11 PM | #14 |
Been smoking cigars since I was 16 (now 71). Used to do EverMores, now MuniMakers (dark). Connecticut broadleaf wrapper, 2-4 a day.
Paul |
12-29-2015, 08:00 PM | #15 |
Did not want to but now I have to -- my new project a 1913 Maxwell engine turd over by hand with really great compression -took the intake manifold off found hand fulls of nuts jammed around the valves 20 hrs later still almost have this crazy L shaped head off better safe than sorry I guess...
