Old 05-17-2021, 06:55 PM   #1
flathead34
flathead34's Avatar
Default 1935 Turtle Gear tooth Count
For our 1935 Ford, what is the correct number of turtle gear teeth. Is 19 or 20 teeth with 16" tires
flathead34 is offline   Reply With Quote
Old 05-17-2021, 07:00 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: 1935 Turtle Gear tooth Count
It depends also on the ring and pinion ratio. This chart should help you figure it out. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 05-17-2021, 08:23 PM   #3
flathead34
flathead34's Avatar
It is a 9:34 pinion/gear ratio
Old 05-17-2021, 08:36 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
OK, look in the first column (9:34 = 3.78), rows 11 & 12 = 16" Tire
Results in a #19 Turtle (19 Teeth) w/6.00 X 16" Tire
DD
T5 W/TORQUE TUBE
Old 05-17-2021, 09:09 PM   #5
1939mars
1939mars's Avatar
Be sure when you select your part that you actually count the number of teeth instead of just going by what the number on top of it says. The gears can be replaced. I substituted a different gear number on my pickup and marked what it is on the case with a paint pen, but not everyone might not have gone to the trouble.
1939mars is offline   Reply With Quote
Old 05-17-2021, 09:54 PM   #6
flathead34
flathead34's Avatar
Thanks guys for the table and how to interrupt it. That is a real help not only for me also for other Barners who read the post. Happy V-8ing. Mike
Old 05-18-2021, 12:06 AM   #7
cas3
Mr flathead34, if you have a hankerin to play with old fords, you should buy the "green bible" all info for parts interchange up to 48 is there. Tons of fun, available in reprint
Thread Tools
Display Modes
