05-21-2019, 04:53 PM | #1 |
Runtz Failures
The scene in the photo below was with 1/4 tank on the fuel gauge, which has been very accurate in the four years since I converted to 12 volts, using three Runtz voltage reducers on Fuel, Oil pressure, and Temperature.
When I filled the tank, the fuel needle went completely out of sight on the high end. Ignition off, it the needle settles at just below the empty mark. I replaced the Runtz on the fuel gauge with a spare, and the needle still went off scale high. I tested the removed part and all three installed Runtz and found all four to be putting out 8 volts. With 8 volts on the oil pressure gauge and the engine off the oil pressure reads 10 psi. That is a big problem. When first converted to 12 volts, the oil pressure gauge matched the mechanical gauge. So, in four years of light use all four Runtz failed in the same mode, namely putting out 8 volts instead of 6. Very odd. Just glad they did not fail to 12 volts; all of the gauges survived the voltage failure. I have an spare CPT voltage reducer rated at 7 amps for the wiper motor and heater fan. It bench tests at 6.1 volts. I will report back after that is installed. I will be interested to see the effect of correct voltage on engine temperature indication, as that has been reading hot. Wishful thinking! |
05-21-2019, 06:49 PM | #2 |
Re: Runtz Failures
You can get 7805 in 5-volt or 7806 in 6-volt and fabricate an IC type CVR. You might try testing your gauges with a 6-volt lantern battery or what have you. At least you can test the gauge.
The old 6-volt systems made 7.1 to as high as 7.5 volts to charge the battery. 8-volts is a bit high but may offer a bit more amperage. The amperage is cut back quite a bit on some. Where did your IC chip type VRs come from? Randy Rundle should have some sort of warranty on his units within reason. Others, I don't know. They have to be properly set up in fabrication to work but they are generally pretty reliable as long as the polarity is never compromised. Last edited by rotorwrench; 05-22-2019 at 12:46 PM. |
05-21-2019, 07:08 PM | #3 | |
Re: Runtz Failures
Maybe someone would stick a voltmeter on an installed Runtz output (the flat piece that bolts to the instrument) with the ignition on, but engine not running. |
05-22-2019, 02:37 AM | #4 |
Re: Runtz Failures
Could never understand the wisdom of putting a 'Runtz' or any other reducer on each gauge when a single reducer would take care of the whole gauge cluster.
The same way Ford did it when they went to 12 volt systems and kept their 6 volt gauges. The same type as used on '64-'65 Mustangs and which I have been using for over 20 years with no issues.
05-22-2019, 02:59 AM | #5 |
Re: Runtz Failures
I junked my Runtz yrs ago and went with a gauge guy in Idaho who made his own volt drops using diodes.He claims that the orig Ford gauges are truly a 5V,not 6.Never ever had a problem since and always accurate.He is now retired.
05-22-2019, 04:03 AM | #6 |
Re: Runtz Failures
Less voltage they just works slower...anything between 5-8v should work just fine. But if the regulator can´t deliver the current needed they start acting funny... |
05-22-2019, 08:29 AM | #7 | |
Re: Runtz Failures
05-22-2019, 10:19 AM | #8 |
Re: Runtz Failures
Made my own 12V to 6V reducers using these instructions. Cheap, easy to build and they have been working flawlessly for the past 20 years. I mounted mine right on the back of the gauge cluster.
http://www.studebaker-info.org/Tech/6-12V/6-12-6.html |
05-22-2019, 01:10 PM | #9 |
Re: Runtz Failures
Some folks use the heat sinks like that and some don't. The ones made by sources other than Randy Rundle may be suspect. If they are all showing 8-volts then they may be 7808 VRs. They make them in about every voltage you can imagine. A lot of electrical guys recommend the 5-volt 7805 type CVRs but I don't know if it will make a big difference. The KS instuments will take whatever current that they draw at any given reading. The lower voltage will keep the heat down in the units. I think that's why Randy Rundle recommended to use just one Runtz per instrument. The more you draw the hotter it will get.
Many of the repop instrument voltage regulator replacements have a 7800 series IC VR inside. The original ones were chopper types. They work the same way the gauge does on King Seeley systems. They have a heater coil around a bi-metallic strip with a little set of breaker points to regulate the voltage. If you put an old d'arsonval type volt meter on them, the voltage reads all over the place because it's constantly opening and closing the points. With a solid state CVR the voltage is "constant" as it should be. There may be other problems brewing in the system like a loose terminal or something of that nature causing the instruments to read funky. That's why I suggested a test with a 6-volt battery. If nothing else, a person can see if it changes the readings. |
05-22-2019, 02:28 PM | #10 | |
Re: Runtz Failures
'52 F-1, EAB flathead |
05-22-2019, 04:18 PM | #11 |
Re: Runtz Failures
How do you check one of the Ford CVR units to see if it is working properly? Can you use a multimeter?
Matt 24:36-41 |
05-23-2019, 10:19 AM | #12 |
Re: Runtz Failures
So, replaced all three Runtz that were putting out 8 volts with a single voltage reducer that puts out 6.1 volts. Much to my chagrin, the problem is not fixed. Oil pressure reads about 10 psi with the engine off and Temp sits at 1/4 deflection with the engine cold. Fuel gauge went almost out of sight high with a full tank.
What would cause all three instruments to read high? Anybody else ever have this problem? First rule of electricity: " If something is acting weird, check the ground path." Seems most unlikely, but I will check instrument panel ground. Did I mention how much I hate working under the dash? |
05-23-2019, 12:27 PM | #13 | |
Re: Runtz Failures
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 05-23-2019 at 12:52 PM. |
05-23-2019, 12:31 PM | #14 |
Re: Runtz Failures
What sending units are you using, originals or repro?
05-23-2019, 12:43 PM | #15 |
Re: Runtz Failures
05-23-2019, 01:14 PM | #16 |
Re: Runtz Failures
None of the reproduction senders hold a candle to the OEM King Seeley units but a person has to find either good used or old NOS stuff.
On the fuel sender, there may be a problem with the float. If it fell off then it could read about anywhere on the gauge. When they get a pin hole, they sink to the bottom. |
05-26-2019, 10:43 PM | #17 |
Re: Runtz Failures
05-27-2019, 12:09 PM | #18 | |
Re: Runtz Failures
I checked the ground at the gauges and no problem there. I will try different oil pressure and temperature senders to see if that helps. If it turns out to be the gauges, I will just learn to live with gauges that are not correctly calibrated. |
05-27-2019, 02:52 PM | #19 |
Re: Runtz Failures
The GROUND in question is NOT at the gauge but at the SENSOR i.e. ENGINE.
05-27-2019, 03:16 PM | #20 |
Re: Runtz Failures
Yes, the sender/sensor IS the ground path for the gauge. The sender/sensor regulates the current flow to ground. That current flow through the gauge heats a coil which bends a bi-metal connection to the indicator. In the original senders a set of points open and close at a various rates to control the current through the heater coils. Reproduction senders use variable resistance to control the current flow.
