Old 02-12-2017, 06:08 AM   #1
tomkc1
tomkc1's Avatar
Default 1934 Starter Wrrrrrr
I had my starter rebuilt less than a year ago. Lately its been making a wrrrrr sound sometimes when I try to engage it. Sometimes it starts right up. I brought it back to the rebuilder and after checking the starter (including the Bendix) he retuned it to me (no charge) and said he thought it was low voltage.
The 6 volt battery is new and the headlights shine brightly. I suspect its one of the battery cable wires.
What is the gage of these wires? Does someone make a set of them specifically for a '34 Ford where I could call them and have them sent to me? Mine are very old.
Could the problem be something else?
Thanks in advance. Tom
tomkc1 is offline   Reply With Quote
Old 02-12-2017, 06:31 AM   #2
flatheadmurre
flatheadmurre's Avatar
Default Re: 1934 Starter Wrrrrrr
If it´s spinning free without engaging means the acceleration doesn´t overcome the little springload and friction so either not enough power, lack of lube or dirt preventing smooth movement.
When it engages does it crank fast as it should or to slow ?
I would start by checking how smooth the bendix moves.
Make sure the connections of the cables is good including grounding.
Cables if they are not corroded or insulation is gone should work just fine.
Old 02-12-2017, 07:00 AM   #3
tubman
tubman's Avatar
I think The Brillman Company has exact reproduction battery cables for early Fords (among others).
Old 02-12-2017, 12:35 PM   #4
tomkc1
tomkc1's Avatar
Flatheadmurre when it engages it is not slow. It starts the engine right up. Sometimes it will wrrrr 3 or 4 times in a row and then engage correctly.
Old 02-12-2017, 04:41 PM   #5
Dave Mc
Dave Mc's Avatar
Worn ring gear on flywheel ? teeth chewed away ?
Any man who thinks he can be happy and prosperous by letting the Government take care of him, better take a closer look at the American Indian!" - Henry Ford
Dave Mc is offline   Reply With Quote
