12-06-2022, 05:02 PM | #1 |
master cyl for '33 hyd. update?
master cyl for '33 hyd. update? Is there a specific one for early V8s?
Thank you. |
12-06-2022, 05:05 PM | #2 |
Re: master cyl for '33 hyd. update?
Its called steeldralics.
12-06-2022, 05:22 PM | #3 |
12-07-2022, 10:50 AM | #4 |
My personal preference is for a stock replacement 39-48 cylinder. Use all stock 39-48 fittings and hoses.
Mart. |
12-07-2022, 11:04 AM | #5 |
12-07-2022, 03:53 PM | #6 |
Early ford 3 bolt master cylinder w/dual reservoirs – Carrillo customs speed and coachworks Early ford 3 bolt master cylinder w/dual reservoirs all new 3 bolt master cylinders combine tradition and a little modernization for added safety. No more need for a adapter. Master cylinder is 1” bore. No built in residuals. May need residual valves and proportioning valve added to brake lines. works with drum/drum and disk/drum.
Making the simple complicated for over 30 years. |
12-07-2022, 04:35 PM | #7 | |
bad link.
12-07-2022, 08:07 PM | #8 |
Trying to get the earlyv8garage to respond. They make a great conversion kit for mechanical brake Fords. I like the 62/63 Cad dual for drum/drum same tubing as 39 up Fords. Newc
