Old 03-29-2024, 09:21 AM   #1
Bob Bidonde
Bob Bidonde's Avatar
Default Cooling Air Flow Experiment
With the hood closed, run the engine at a fast idle. Pass a piece of paper towel lengthwise along the louvers in the hood. Note how the towel moves. There will be interesting variations in the air flows.
Bob Bidonde
Old 03-30-2024, 10:35 AM   #2
katy
katy's Avatar
Default Re: Cooling Air Flow Experiment
So?
Old 03-30-2024, 10:53 AM   #3
Bob Bidonde
Katy, I have no conclusion or recommendation for my post. It's just something to do. Have you tried it?
Bob Bidonde
Old 03-30-2024, 11:00 AM   #4
katy
katy's Avatar
Haven't tried it, don't intend to., don't see any need for it, car cools fine the way it is.
Old 03-30-2024, 01:50 PM   #5
Big hammer
With my hood off the air flows backwards at an idle, radiator upper corners ?! I covered the radiator trying to warm it up faster and the towel blew from the radiator. Weird things happen
get a bigger hammer tap done
Old 03-30-2024, 02:39 PM   #6
mass A man
mass A man's Avatar
Perhaps your test would show something with and without the engine pans?
mass A man is offline   Reply With Quote
Old 03-30-2024, 05:00 PM   #7
Randy in ca
Randy in ca's Avatar
My thought too.
Randy in ca is offline   Reply With Quote
Old 03-30-2024, 05:42 PM   #8
ursus
Use of an infrared heat gun test device over the face of a radiator will show fairly uniform temps at various sections on a very good one. Most radiators will show a mix of hotter and cooler spots.
Old 03-31-2024, 10:05 AM   #9
Bob Bidonde
Katy, you miss the point of the experiment, that is to try something for fun and perhaps learn something.
Yes, the air flow changes when there are no engine side pans installed.
Bob Bidonde
Old 04-01-2024, 07:51 AM   #10
spdway1
spdway1's Avatar
Some people have way too much time on their hands - Stop thinking.
spdway1 is offline   Reply With Quote
Old 04-01-2024, 09:00 AM   #11
Y-Blockhead
Y-Blockhead's Avatar
I think a few members need to lighten up...
Old 04-01-2024, 05:24 PM   #12
AL in NY
AL in NY's Avatar
I don't see what this experiment tells you. A better experiment, if possible, would be to do this same experiment at 40 MPH with the engine pans in place to see the ACTUAL airflow while cruising.
AL in NY
AL in NY is offline   Reply With Quote
Old 04-01-2024, 05:31 PM   #13
nkaminar
nkaminar's Avatar
I see in my mind an array of pitot tubes and a bank of manometers in the cab. Also needed is a clip board and someone to sharpen pencils.
Old 04-02-2024, 07:26 AM   #14
marty in Ohio
marty in Ohio's Avatar
I have to agree with Bob. He's in cold New York and I'm in cold Ohio. We can't drive 'em in the winter so we play with them. Keeps the mind active. Mine cools fine too but why not experiment and learn?
Marty
marty in Ohio is offline   Reply With Quote
Old 04-02-2024, 07:33 AM   #15
Bob Bidonde
Thanks Marty In Ohio!
Bob Bidonde
Old 04-02-2024, 12:20 PM   #16
Canton_Model_A's
Canton_Model_A's's Avatar
Guess those of us where we get cold/snow get cabin fever and want to drive our cars!
1929 Model A Tudor
"Stay away from negative people, they have a problem for every solution"
Model A Ford Club of America
Model A Restorers Club
Motor City A's Club
Canton_Model_A's is offline   Reply With Quote
