Old 07-28-2020, 10:12 AM   #1
tinman7
tinman7's Avatar
Default Horn bracket
If I unbolt a head bolt to attach a horn will it be a problem with the head gasket?
tinman7 is offline   Reply With Quote
Old 07-28-2020, 03:39 PM   #2
jimTN
Default Re: Horn bracket
No as long as the bolt is long enough to go thru the bracket and have sufficient threads to tighten.
Old 07-29-2020, 08:30 AM   #3
Will N
Will N's Avatar
You should drain all the water from the radiator first. Then, when retightening, loosen all the head bolts and re-torque them following the correct sequence.
Will N is offline   Reply With Quote
Old 07-29-2020, 10:11 AM   #4
stevests
stevests's Avatar
No - done it multiple times for horn repair or replacement.
stevests is offline   Reply With Quote
