06-25-2020, 11:06 AM | #21 |
Re: Mercury VIN Decoder
Wow, thank you!
08-13-2023, 09:23 PM | #22 |
Did Mercurys built before 1948 have a body tag that would tell the color , drive line information?
08-13-2023, 09:53 PM | #23 |
The factory Serial # of my 51 Merc is stamped on the Patent Plate as posted by Don Rogers AND on the top of the front right frame rail that extends at an angle from the right side frame rail to the center "X" member.
It is located below the lower edge of the firewall. Mine is a 10 digit number with a star stamped in front of the first number and two stars stamped right behind the last number. This number is also used as the VIN number on the Title of the car by the Florida DMV. If you buy a Merc check both locations for the same number. If you own a 49-51 Mercury you must buy these two books. Prices vary so shop around. https://www.then-now-auto.com/produc...-2-volume-set/ and https://www.ebay.com/itm/14233972641...e3c1ece24b1461 Last edited by 19Fordy; 08-14-2023 at 11:00 AM. |
03-15-2024, 12:34 PM | #24 | |
03-15-2024, 12:39 PM | #25 | |
03-15-2024, 02:04 PM | #26 | |
BG70B = 2 Door Sedan 09 = Tahiti Tan 351 = Brown/White Checkered Broadcloth 15K = assembled October 15 169 = rotation number or unit number that day Ken
https://www.nirgv8.org |
03-16-2024, 07:40 AM | #27 |
Thanks!
