Old 03-26-2024, 08:03 AM   #1
Canton_Model_A's
Canton_Model_A's's Avatar
Default Convert 1929 from Negative Ground back to Positive
Here is an interesting question. the Previous owner who did the 12v conversion on my 1929 put it to Negative Ground. My question is, how hard is it to put it back to Positive ground?
I took a look at my 'A' yesterday to confirm. Should I just leave it like this or attempt the conversion back to Positive ground from Negative.
Thanks!
1929 Model A Tudor
"Stay away from negative people, they have a problem for every solution"
Model A Ford Club of America
Model A Restorers Club
Motor City A's Club
Canton_Model_A's is offline   Reply With Quote
Old 03-26-2024, 08:32 AM   #2
Ruth
Default Re: Convert 1929 from Negative Ground back to Positive
Normally when a car is converted to 12v it is also converted negative ground. I would leave it as is.
Ruth
Old 03-26-2024, 08:57 AM   #3
Badpuppy
12V Negative ground is more up-to-date. Makes the A compatible with modern add-ons. There's no advantage to positive ground, unless you're going for originality. And then you have to change back to 6V, which would be a pain. I agree with Ruth, leave as-is.
Old 03-26-2024, 09:03 AM   #4
Canton_Model_A's
ok Will follow the advice here from the experts as I am not. Thank you
1929 Model A Tudor
Motor City A's Club
Old 03-26-2024, 09:06 AM   #5
Kurt in NJ
Kurt in NJ's Avatar
It depends on what modifications were made, what does it have for generator/ alternator?
Old 03-26-2024, 09:13 AM   #6
Canton_Model_A's
it has from what I gather, an AC Delco Alternator, LED turn signals, LED brake lights, standard incandescent headlights now (converted back from sealed beam)
1929 Model A Tudor
Motor City A's Club
Old 03-26-2024, 12:02 PM   #7
nkaminar
nkaminar's Avatar
This raises more questions than it answers. Why would you want positive ground? Do you also want to convert it back to 6 volts (at great expense)? Has the starter motor been converted over to 12 volts (all field windings in series)?
Regarding the headlights: Do you drive at night often? If so you could consider the self focusing LED lamps or converting over to halogen lamps (that the alternator will handle OK but the light switch may not).
Old 03-26-2024, 12:15 PM   #8
Canton_Model_A's
From the starter prospective, I can't answer, but I would assume it was. Headlights, I sometimes do drive it at night, but not so often. I de-converted from Sealed-Beam back to the original style bulbs, and put period correct onto the car.
If there is no need to go back to Positve-Ground keeping it negative ground is fine by me
1929 Model A Tudor
Motor City A's Club
Old 03-26-2024, 03:30 PM   #9
ModelA29
ModelA29's Avatar
LEDs are diodes so they have specific + - power path not like a regular bulb.
ModelA29 is offline   Reply With Quote
Old 03-26-2024, 04:00 PM   #10
Y-Blockhead
Y-Blockhead's Avatar
The new LogoLites LED headlghts that nkaminar refers to are both + or -, 6v or 12v compatable.
Old 03-26-2024, 06:05 PM   #11
Flathead
Flathead's Avatar
Leave it negative ground, you are past the point of no return.
Flathead is offline   Reply With Quote
Old 03-28-2024, 10:57 PM   #12
spdway1
spdway1's Avatar
What are you looking to achieve?
spdway1 is offline   Reply With Quote
Old 03-29-2024, 12:33 AM   #13
jetrod
I see no reaon to convert to 12 volt, I use 6 volt to run my GPS. That is all I need. JR
jetrod is offline   Reply With Quote
