Old 04-13-2024, 10:47 AM   #1
Kube
Kube's Avatar
Default '31 pickup rear fender filler panels
Hello folks...
Okay, I admit I am lost.
I am attempting to figure out where the filler panels get attached to the fenders.
Rear fenders (you knew that) on a '31 pickup truck.
I have nice authentic coupe fenders and reproduction filler panels.
I believe what would really help is perhaps a dimension from the lip of the fender leading edge to where the panel "starts".
Photos?
Thanks guys.
Old 04-13-2024, 11:09 AM   #2
Jim Brierley
Default Re: '31 pickup rear fender filler panels
If yours is a late '31, it has narrower fenders and no fill panel. Late 31's have the fuel shut-off on the front side of the firewall, a dropped steering support, not attached to the gas tank, and a longer, wider bed.
Old 04-13-2024, 12:04 PM   #3
Bob C
Here's a picture from Snyder's that may help.
https://www.snydersantiqueauto.com/p...9547&cat=41818
Old 04-13-2024, 01:03 PM   #4
Kube
Kube's Avatar
Early '31. Bob, that illustration is perfect for me. Thanks so much!
Old 04-13-2024, 01:54 PM   #5
Hitman
Don't forget to add the fender mounting carriage bolts to the filler strip before you rivet them to the bed. They don't fit once it's on, so which would require use of the undersized bolt.
Hitman is offline   Reply With Quote
