10-09-2021, 11:00 AM | #1 |
Model B Parts Vendor
Who are you “Go To” vendors for the basic Model B parts.
Having a hard time finding Things like rear main drain tube, oil fill/breather tube, etc. |
10-09-2021, 11:24 AM | #2 |
Re: Model B Parts Vendor
All Ford Parts Campbell, CA
allfordparts.com |
10-09-2021, 11:59 AM | #3 |
Try placing a "wanted ad". The parts you are looking for are more likely to be under someones bench instead of with a vendor.
Charlie Stephens |
10-09-2021, 05:57 PM | #4 |
Snyder's in Ohio (snydersantiqueauto.com) carry a fair number of B parts including the rear main bearing drain tube. They offer a oil filler tube with the baffles as original, but it is the Model A version. The early Model B oil filler tube is the same diameter as the Model A tube, but the B version is longer and somewhat scarce. The late Model B oil filler tube's upper diameter is much larger as is the cap used with it. I do not believe that either B tube was ever reproduced, but the later, larger type is not the least bit rare. Try Michael Driskell at Third Gen Auto for an original of either type.
10-10-2021, 07:40 AM | #5 |
DavidG, thanks for the leads, I’ll look into this
10-10-2021, 09:18 AM | #6 |
