07-30-2021, 04:49 PM | #1 |
Update from the Ace Mechanic
So friends have come to the conclusion that the solenoid is trash. When out on the bench and 6V power is applied to it the plunger just oscillates in and out. I an told it should snap in and stay there, so at this point I am going to send it to Tom Endy, if he will have it. Anyone near Danville, Ca selling one?
Thanks to all who helped. |
07-31-2021, 08:33 AM | #2 |
Re: Update from the Ace Mechanic
Enlighten us as to what sol you're speaking of or send us to the original post please.
Paul in CT |
07-31-2021, 11:20 AM | #3 |
Did you use a good battery and heavy wire to test the solenoid? It take quite a bit
of current to pull the solenoid in then the holding windings take over. Have you seen the BW manual Tom Endy posted? http://www.santaanitaas.org/wp-conte...ner-manual.pdf |
07-31-2021, 12:47 PM | #4 |
Dave, Is this for a Borg-Warner overdrive?
07-31-2021, 12:55 PM | #5 |
07-31-2021, 04:39 PM | #6 |
07-31-2021, 08:11 PM | #7 |
okay important question Davey! Who nicknamed you Ace Mechanic?
07-31-2021, 09:08 PM | #8 |
Snoopy in France, 1917, over a fag and coffee as I repaired his Sopworth Camel, shot up by the Red Baron.
08-01-2021, 01:29 AM | #9 |
08-01-2021, 07:47 AM | #10 |
I am no BW expert but is it possible that the solenoid is 12 volts not 6?
