Old 07-28-2021, 09:11 PM   #321
sugarmaker
sugarmaker's Avatar
Default Re: 1932 The Deuce, Dually, Dump Truck
Folks,
Back to this B engine.
Removed the rod caps, and removed the pistons. Found at least one broken ring.
Babbit in center upper bearing was very bad and partially missing.
Rear upper:
Front upper:
Rod bearing babbit all looked similar:
Grandson Mike was over to visit and look at the 32 for the first time. He works as a technician/ mechanic for Firestone. He helped me set the hood and grill back on the truck. Checked it out, and cant wait to drive it!
Regards,
Chris
1932 AAB Truck
1953 Ford Jubilee
2015 Ford F250 SuperCrew
Lots of Allis tractors
Some Cub Cadets
Old 07-28-2021, 09:46 PM   #322
GB SISSON
GB SISSON's Avatar
Center upper babbit? That is TOAST! Glad you didn't decide to just get it running, You'd be looking for a crank (if you aren't already) Yikes
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 07-28-2021, 10:57 PM   #323
51504bat
51504bat's Avatar
I'd check with Ft. Wayne Clutch for a replacement PP and clutch disc. If you can find a new ring gear installing it is a piece of cake. Put the flywheel in the freezer and heat the neat ring gear on the barbie (mama's oven works as well but not recommended) The ring gear will slide onto the flywheel and lock in place.
https://fortwayneclutch.com/
Old 07-29-2021, 07:16 AM   #324
sugarmaker
sugarmaker's Avatar
Gary, 5150, folks,
Yes was glad I did not get excited and try to start this engine. Parts will be evaluated for goodness/ rework.
Thanks for the clutch information. I have done ring gears on Allis engines heated the ring gear in the oven to correct expansion and it dropped right on. I believe that will be in the list of things to do also. (The list is growing.) Even though the plan is to not do a full restoration on the truck. the mechanics take about the same amount of work to get them correct.
Wed balanced the shop projects with some time on 17,000 acre pond on PA/ OH line.
Friend Jim with the catch of the day. But was very good to get out on the very calm water in his nice boat!
Friend Brent showing us where the fish are/ were?
Regards,
Chris
1932 AAB Truck
1953 Ford Jubilee
Some Cub Cadets
Old 07-29-2021, 10:29 AM   #325
DavidG
DavidG's Avatar
Pymatuning, right?
Old 07-29-2021, 12:13 PM   #326
sugarmaker
sugarmaker's Avatar
David,
Folks,
Yes right on the mark. Pymatuning Resevoir. Not sure where all the fish were?
On the 32 engine: Removed all the head studs. I believe those will be replaced with new ones, as some have corrosion concerns. Removed the keepers from the valves. Pulled out the valve springs. Valve guides?? Havent started that yet.
Regards,
Chris
1932 AAB Truck
1953 Ford Jubilee
Some Cub Cadets
Old 07-29-2021, 08:12 PM   #327
Zeke3
Zeke3's Avatar
I have a tool for knocking those guides out, PM me if you would like to borrow it. It is shaped a little different than the Snyder's tool.
Zeke3 is offline   Reply With Quote
Old 07-29-2021, 09:37 PM   #328
sugarmaker
sugarmaker's Avatar
Zeke, Folks,
Thanks, The guides are out, valves are out. cam is out. Nono of it was pretty and am not proud. But we are going with new style components in this engine so these were not going to be used. No children were harmed during this process!
The engine is at the machine shop and we will begin the process. First look found a couple things. Like the cracked #2 cylinder will be sleeved.
Hope to get it back with a bow on it!
Regards,
Chris
1932 AAB Truck
1953 Ford Jubilee
Some Cub Cadets
Old 07-30-2021, 12:28 PM   #329
Mart
Mart's Avatar
Do you think it might be an idea to just look for a good running 4 cyl engine? Must be some around that have been taken out of hotrodded cars?
Mart.
Old 07-30-2021, 01:34 PM   #330
Floyd
Fix the one you have because you know what you have and it is a typical job to sleeve a cylinder. Besides you are going to make it perfect (inside ) anyway. Babbiting B engines are done every day. (Dreamwerks-NC ) . Also that engine has hauled that truck around faithfully for years. You can't throw out a dog just because he his old.
When mechanically perfect, re-apply the dirt and grease to the not repainted outside and with the later V8 clutch assembly rebuilt by Fort Wayne, you will be on the road!!
Floyd is offline   Reply With Quote
Old 07-30-2021, 09:09 PM   #331
sugarmaker
sugarmaker's Avatar
mart, Floyd,
Both those options are on the table. But My current plan would be to rebuild the engine that I have into a good servicable engine with some changes/ upgrades that exist today.
Namely replaceable bearing inserts for mains and rods. have the one cylinder sleeved. bore the block for next oversized pistons. valves and seats with adjustable lifters.
thats about it.
Now if a good used engine appears I will surely consider that too, as this is not the original engine in the truck.
The 32 got to go outside for some sun, while Jim from Bugs & Tugs helped me rearrange some things in the shop. Just some glamor shots!
My view from the shop couch as I browsed through the Ford V8 club magazine this evening.
Really thrilled with the two 32 Ford books that David G. has authored. That are wonderful. Packed with details information and pictures.
So I believe it was mentioned in a earlier post but I believe the color on my truck is or is close to the Washington Blue.
I have so much to do on this truck it seems overwhelming at times. But have been through these projects before so Just need to go slow and keep hitting at it a little each day.
Today I worked on the interior walls of the shop. Starting the lengthy process, one board at a time.
Regards,
Chris
1932 AAB Truck
1953 Ford Jubilee
Some Cub Cadets
Old 07-30-2021, 09:33 PM   #332
Tinker
Tinker's Avatar
Mart.
Mart, it's a B motor. But I agree if you run across another why not pick it up. If I can be 2 deep with parts I will. Once you get to 3-4 of the same part you might be a hoarder or a smug dude.
Old 07-31-2021, 07:39 AM   #333
sugarmaker
sugarmaker's Avatar
Tinker, Folks,
I skirt around the edges of being a hoarder. I understand the concept! Have seen it in action too. Might get there someday too. Thanks for the comments Always welcome!
Off to try to get started on wood working today.
So is there a place where all the B Engine specs are stored? Like the dimensions for the crank journals? My machinist wants me to give him the specs. I will find them eventually, I havent looked too hard yet.
I plan to get the trans on the engine stand soon for cleaning and evaluation.
Also have to try to get the water pump apart for review of the shaft. Any hints on that would be appreciated too.
A big shout out to Don Snyder of Snyder's Antique parts. I called with a tech question about the intermediate shaft from the distributor to the oil pump drive. I did not know how this came apart. (simple slip fit) Mine was rusted into the oil pump sleeve. Don assured me that a pair of vice grips on the shaft and some taps with a hammer would release it he was correct! Little things like that really help someone who doesn't know what they are doing.
Ok I have these old seat springs that were in the truck. They may or may not be the correct back springs and the bottom ones are not correct. But if anyone might need these for a project I would be willing to let them go.
Regards,
Chris
1932 AAB Truck
1953 Ford Jubilee
Some Cub Cadets
Old 07-31-2021, 09:14 AM   #334
Bored&Stroked
Bored&Stroked's Avatar
Hey Chris - heck of a nice building/shop you have there . . . love that overhead hoist you have setup - wouldn't we ALL like to have that!
Old 07-31-2021, 10:52 AM   #335
Bob C
I think this link to Vince's site has the bearing and crank info you want.
http://www.fordgarage.com/pages/AERbearinginserts.htm
Old 07-31-2021, 09:58 PM   #336
sugarmaker
sugarmaker's Avatar
Bored&Stroked,
The jib was on the wish list for the building. Luckily my neighbor had this stuff (steel) laying back in the weeds! 12 inch pipe about 13 feet above the floor, 6 foot hole, 3 foot dia. poured a 1 foot thick concrete pad for the post to set on. Rebar frame embedded in that base. set the post them poured a yard of concrete around the post. next poured the pipe full of concrete around the 4 rebars I had inserted. The frame is my design. Has Allis WD bearings in the pivot joints. Friend Matt H made the pivot pins. Dayton hoist was picked off facebook market place and repaired. Trolley was given to me by friend Brent H. Jib only has a lift height of 8 feet, hook to floor, but is real handy. Swings 180 into centers of both inside door ways.
A lift of some type has not appeared yet!
Bob, thanks for the link. Wow lots of information there!
Whooped on this end to today, the wood and coating got the best of me!
Side note: We did have the first sweet corn from our garden today!
Regards,
Chris
1932 AAB Truck
1953 Ford Jubilee
Some Cub Cadets
Old 08-02-2021, 06:32 AM   #337
sugarmaker
sugarmaker's Avatar
Ford Folks,
Pretty quiet on the 32 progress.
Will work with Valley Machine to get the specs for the engine and dimension and then Snyder's for the proposed parts required. That may take a week or so.
A good friend John R stopped by and brought me some spare parts he had. Great to have good friends in Ford places! The intake manifold looks like it would work fine if needed. The water pumps and fuel pump are from something else.
I had to climb in the cab yesterday for a couple minutes. John said he might have a turn signal switch like mine.
Yes the 70+ year old cloth electrical tape is still there too! No clue about the wiper motor?
Making some progress in the shop on the wall coverings: Cutting to length, sanding, coating, re coating, installing. Its going to look pretty good.
The small room in the corner is for a vertical air compressor. Thinking of getting a 80 gallon and leaving the 60 gallon Kobalt, in the house garage. The small room is to insulate some noise. Still have to drill the vent holes in the lower steel for air inlet.
Regards,
Chris
1932 AAB Truck
1953 Ford Jubilee
Some Cub Cadets
Old 08-02-2021, 06:38 AM   #338
Pat/Ohio
Pat/Ohio's Avatar
Chris, The water pumps and fuel pump are V8 items. Love this thread!
Stay Safe!
Pat
Pat/Ohio is offline   Reply With Quote
Old 08-02-2021, 07:25 AM   #339
sugarmaker
sugarmaker's Avatar
Pat,
Thanks for the quick response on the water pumps. Another mystery solved. Maybe the fuel pump is for the V8 also?
Glad you have enjoyed the thread. I do go off in the weeds some too.
Regards,
Chris
1932 AAB Truck
1953 Ford Jubilee
Some Cub Cadets
Old 08-02-2021, 08:39 AM   #340
DavidG
DavidG's Avatar
Chris,
The windshield wiper motor is the original or one exactly like the original.
Your shop is beyond the pale. I am jealous.
