08-08-2011, 01:09 PM | #1 |
New disk brakes
Has anyone installed the new disk break system that's just came on the market. If so I would like your comments as I am thinking of installing them on my 15 touring this winter. Thanks Frank pkny
08-08-2011, 08:11 PM | #2 |
Re: New disk brakes
well i havent seen the new system but a buddy of mine had a system custom built with a set of rear calipers of a expedition, i think the rotors were specaly made. i have drove the car and it stops really well, nothing like the old trans brake.
08-08-2011, 10:42 PM | #3 |
Re: New disk brakes
I was just looking at the installation instructions from "Texas T Parts" this morning. This instruction page was for the large drum wire wheel application, so I don't know how it would apply to the small drum wood wheels of 1915. It is definately impressive. My main concern would be the stresses put on other suspension items and the wood wheels as well. Locking up the rear wheels sure would be an improvement. Check their web-site, maybe they could have you talk with some recent customers. Good luck.
08-08-2011, 11:35 PM | #4 |
Re: New disk brakes
I have no external brakes on my T and I can lock the brakes at will. Kevlar bands are the only change I made.
08-09-2011, 08:58 AM | #5 |
Re: New disk brakes
I guess I'll have to get new Kevlar bands.
08-09-2011, 01:11 PM | #6 |
Re: New disk brakes
08-09-2011, 07:03 PM | #7 |
Re: New disk brakes
I like some type of external brake at the rear wheels. In some years of driving, I have broken one U-Joint on tour and I have broken one axle here on the farm. I feel that some extra braking is needed cause that drive line can break leaving you with no brakes and that is a scary thought. If nothing else, use the linned emergency brake shoes. I am talking pre 26/27.
08-09-2011, 07:32 PM | #8 |
Re: New disk brakes
May I hi-jack this thread lightly?
I know there are small and big rear drums, and I am trying to figure out what I have. The outer diameter of my drums is about 11-1/8 inches, give or take an 8th. Are those the "large" ones or the "small" ones? |
08-09-2011, 08:04 PM | #9 |
Re: New disk brakes
A good question about these disk brakes would be would they hold the wheel on if you brake an axel. I think so but will email and ask that question.
Brother Hesekiel you have the 26 27 large drums.
08-09-2011, 08:32 PM | #10 |
Re: New disk brakes
well frank pkny if u wont to keep it more peroid correct u could always go with a rocky montain set up. had a set on a speedster build i did any i was really happy with the system.
08-09-2011, 08:46 PM | #11 |
Re: New disk brakes
Also consider in a panic stop, which direction is the rear of the car going to go if and when you lock both back tires. Can you really modulate the brakes that well when a crash is imminent?
08-10-2011, 11:14 AM | #12 |
Re: New disk brakes
I always used lined brake shoes on my small drum cars and they work remarkably well if you get in a pinch. The very best way to stop any T is not drive fast to begin with. These old Fords weren't designed for the nice roads we have today, and it's easy to exceed the speed at which these cars were meant to run.
08-10-2011, 11:55 AM | #13 |
Re: New disk brakes
John I agree with you 100% I guess I'm just a tinkerer and a worrie wort. But I do feel the disk brake would surve a dual function . Stoping and keeping a broken axel from expelling the wheel off. I do have the lined shoes as well .
08-12-2011, 04:18 PM | #14 |
Re: New disk brakes
I just received a set of the Texas T discs a couple of days ago,haven't started to install yet.The kit looks good and very complete right down to brake fluid.I'll post some comments after the brakes are installed.
08-14-2011, 09:51 AM | #15 |
Re: New disk brakes
Any time you can install a modern improvement to an old piece of iron, I am all for it. As long as you can remove it and it won't detract from the autos original design. John hit it right on concerning speed, and we don't want to create a false sense of security. Think safety first and check out the entire running gear while installing new brakes. Just an opinion.
08-14-2011, 02:25 PM | #16 | |
Re: New disk brakes
In Model T terms that would be anything going in the direction of a Shay: old looks with more modern components, such as a Pinto engine, non-rusting fiberglass fenders, 4-wheel juice brakes, etc. Sorry, but that goes against anything I believe in when it comes to experiencing old cars. I don't just want them to look old, to be pretenders; I want them to be genuine and authentic windows into the past. As you stated, "just an opinion"; and we'll have to agree that we disagree here. Unless somebody tells me that the period correct Rocky Mountain brakes are unable to stop a Model T, I think it's a move in the wrong direction to install disk brakes. What's next? |
08-14-2011, 03:37 PM | #17 |
Re: New disk brakes
If you can lock the brakes with standard brakes, are external brakes going to lock the brakes tighter or faster? No matter what kind of brakes you have, there is the fact taht you are stopping a moving mass at higher speed with better brakes and skinny tires. Drive the car the way it was intended or drive a modern car. If I put 6 piston calipers on my Taurus is it going to stop faster? If I can already lock the tires, what are better brakes going to do? Also, remember when you do lock the brakes, you know you will, which way is the rear end going to go?
08-14-2011, 04:28 PM | #18 |
Re: New disk brakes
Hey Brother H, all you read was the first sentence. There are many items out there that are good for safety and maintenence on our original autos. Some items can be well hidden (seals, bearings, etc.), and some can't. Some are built to show and some are restored to tour. I assume Frank wants to be safer while touring. That's why I was "all for it" in Frank's case, not something I would do personally. My autos are totally stock, and I would not have it any other way. I would not even install period correct non-Ford items on my "T". Sorry I offended you, will try to use better grammar next time.
08-15-2011, 11:38 AM | #19 |
Re: New disk brakes
I have no problems with taking advantage of better bearing materials, pistons made from aluminum and better brake linings, just to name a few, and I also have no problems with period accessories, such as Rocky Mountain brakes. But once modifications are visible and go in the direction of "modernization" which starts with 2-stage (base/clear) paint, I am against it. That's my personal opinion as a 53-year-old who has been involved with old cars--professionally for the past 25-or-so-- the majority of his life. I'm sure this can be discussed ad nauseam, just like engine oil, but since it was brought up, I felt it's only fair to add my personal opinion. I favor originality very highly and choose preservation whenever possible over restoration.
08-16-2011, 06:27 PM | #20 |
Re: New disk brakes
I have not made up my mind as of now. The input that all of you have given, is in my mind . Rocky mountain brakes were my second choice. But thinking that if the disk brakes would hold the wheel on if an axel breaks that was a good reason to go with them. At present I am still thinking!!!!! Grin.
