04-04-2014, 12:24 PM | #1 |
Oil pan plug questain
I changed the oil in my car yesterday. It's a '48 engine. I haven't been able to find a gasket for the plug. I got a do it your self material at O'Reilly and used the cork material. I used a magnetic Lisle brand plug. Now I have a major oil leak. Where did I go wrong? Thanks for your help
04-04-2014, 12:31 PM | #2 |
Re: Oil pan plug questain
I do not think cork is a good choice. At the very least use gasket material, paper like. I do not have that gasket and my pan does not leak from the drain plug.
04-04-2014, 12:36 PM | #3 |
NAPA has the correct copper compression gaskets for the oil drain plug. Cork or paper will just tear and leak.
04-04-2014, 12:39 PM | #4 |
I also have an O ring.Its small diameter.Do you think it would work. When I took the plug out, didn't look like it had a gasket. It was the stock Ford plug.
04-04-2014, 01:11 PM | #5 |
when changing the oil in my 40 for the first time i noticed there was no gasket, put it back on without one and it don"t leak, should there be one ?.
04-04-2014, 01:36 PM | #6 |
04-04-2014, 01:59 PM | #7 |
Originally there was a gasket.
04-04-2014, 02:05 PM | #8 | |
The copper washers I've gotten recently reflect the high cost of copper; I suspect they have as much copper as a penny these days. They aren't soft enough to do any good. Aluminum is cheap and works great.
'52 F-1, EAB flathead |
04-04-2014, 03:09 PM | #9 |
Most all of the suppliers of old Ford parts such as C&G and Mac's sell drain plug gaskets. I usually buy 3 or so at a time so I have them on hand. Why bother to make your own? JMO
04-04-2014, 04:39 PM | #10 |
Mac van pelt carries them,page 4 of the engine parts
04-04-2014, 05:41 PM | #11 |
I called all over town and couldn't find a copper crush gasket. I ended up with a thick paper gasket the right size. Will see how it works.
04-04-2014, 10:22 PM | #12 |
make one out of a plastic milk jug--needed one quickly and since it works so good I have kept it for 20 years
04-06-2014, 08:52 PM | #13 |
Skim milk in cold weather, whole in the summer?? Gotta match it to the oil...
