04-23-2017, 05:51 AM | #21 |
Re: Front end shimmy
Always check spring perch tapered nuts <2> spring shackles, steering column bolts along with what everyone else mentioned.
mike |
05-09-2017, 09:58 AM | #22 |
05-09-2017, 09:59 AM | #23 | |
They looked okay, round, not oval shaped. Sent from my iPad using Tapatalk |
05-11-2017, 01:13 AM | #24 |
I purchased a Datsun pick up from an individual that shook so hard above 45mph that dust would fall down from the headliner! A front wheel was bent, rotated it to the rear and all was good! I saved you reading the long story version because it wasn't an "A" :-)
05-11-2017, 04:21 AM | #25 |
I purchased my 1931 S/W Fordor last June, and had a terrible shimmy at low speeds. I tightened the drag link which improved things slightly. When I noticed excessive wear on my brand new tires I questioned the toe in. Sure enough, it was 1 1/4"! Once that was fixed the shimmy disappeared completely.
Sent from my iPad using Tapatalk Pro |
05-11-2017, 07:30 AM | #26 |
I would NOT jump to conclusions about bent axles and such without addressing things like worn steering boxes , steering arms worn, loose, spindle bolt bushings, radius cap - do nit use the cast iron rubber ball type .. And as mentioned toe in check and adjust There are many good previous posts out there. After rebuilding countless front axle assemblies you really need to go through all of it to make the car steer and handle as it should... This includes front brakes if they are shot as well. Larry Shepard |
05-11-2017, 10:00 AM | #27 |
Laughingly called "Death Wobble" most of us are familiar with it at one time or another. It is very common. It's caused by looseness of some part OR PARTS, in the front end. Note I added a plural. Thats because It can be more than just your kingpins or your steering balls.
The best way to find it is to jack one wheel at a time and shake it and see what's going on down there. In one of my cars, it was the bushings at the ends of the springs, but I found the bad kingpin first. One expensive cause is a bad steering box. How much play is in the steering wheel? Ideally there should almost none. These can be adjusted. There are four adjustments. Much has been written about them so I won't repeat it here. If you can't adjust the play away, the box must be rebuilt. Good Luck! P.S. Your steering balls on the arms should be COMPLETELY Round at 1.000 dia, If they're out about a 1/32, file them back to round within .020. and start looking for replacements. More than that,and the balls must be drilled out and replaced. Terry Last edited by Terry, NJ; 05-11-2017 at 10:06 AM. |
05-11-2017, 10:50 AM | #28 | |
05-12-2017, 09:35 AM | #29 |
I'd start with a toe in check, then make sure the pitman arm clamp bolt is dead tight, as well as the box to frame mounting bolts.
