06-09-2023, 12:11 PM | #1 |
adjustable lifters
1941flathead ford 85hp: adjustng [email protected]" intake, .016'exhaust. Should I measure just as opposing valve is starting to close, as in exhaust just starting to descend, check/ adjust intake and likewise with exhaust/intake?
06-09-2023, 12:41 PM | #2 |
Re: adjustable lifters
Lifter all the way up then one full turn on crank to put lifter on heal of lobe. that's the way i just did mine.
06-09-2023, 01:16 PM | #3 |
If you can get an older “Motors Manual” they show a sequence where you only have to turn crank 4 times to adjust all valves. I used it and it did save time.
06-09-2023, 06:11 PM | #4 |
Be careful, some methods do NOT put the cam exactly on the heel center.
You will NOT get an accurate adjustment that way. |
06-09-2023, 09:05 PM | #5 |
which way?
06-10-2023, 02:30 PM | #6 |
06-10-2023, 02:40 PM | #7 |
Thanks Pete you scared me for a bit.
06-10-2023, 03:03 PM | #8 |
06-10-2023, 05:41 PM | #9 |
Thanx I'll try kurts method. I put a pointer against the pulley so I can mark it exactly
