11-12-2012, 06:17 PM | #1 |
Replacing a Steering Box ~ Is there a book?
I will be replacing the steering box in my 1946 Ford 1/2 pickup truck. I'm having a core rebuilt by Lares Corp. in MN.
To make things a bit easier, is there a reference book I should have on hand with regard to the wiring & ignition key setup? Or is it straight forward once I get into disassembling everything? Any advice would be appreciated. Thanks! |
11-12-2012, 06:35 PM | #2 |
Re: Replacing a Steering Box ~ Is there a book?
Saganaw 525 works well.
11-13-2012, 06:24 AM | #3 |
save your old one, it would make a good upgrade for a model A
Thank God this is only a hobby! |
11-14-2012, 09:28 PM | #4 |
saginaw 525 work with flathead oil pan et exhaust???
11-15-2012, 04:22 PM | #5 |
I purchased a used 1946 Ford 1/2 Ton PU steering box assembly from a salvager in MN. I then had it shipped to LARES CORP. in MN. to be rebuilt. I will be installing this rebuilt 1946 Ford steering gear in my truck. |
