06-01-2021, 08:55 PM | #1 |
Dyno testing the Flathead for Speedweek
Getting ready for Speedweek our 292 cube Flathead during a soft dyno pull testing the engine and transmission combination. For all the Barn member's who enjoy something a bit different.
Another father and son project all the machine work and assembly. Click on the link below and then turn up the volume up. Ronnieroadster https://www.youtube.com/watch?v=Qa8eaUk-Lhs
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH Last edited by Ronnieroadster; 06-01-2021 at 09:03 PM. |
06-01-2021, 10:03 PM | #2 |
Re: Dyno testing the Flathead for Speedweek
Too cool !!! best wishes on the salt
06-02-2021, 03:08 AM | #3 |
Awesome Ron!! Go get em!!
06-02-2021, 05:14 AM | #4 |
Love it!!
Best of luck Ron! |
06-02-2021, 05:59 AM | #5 |
Go get ‘em! Run fast and safe!
06-02-2021, 05:59 AM | #6 |
06-02-2021, 08:15 AM | #7 |
Cool. Thanks. GO MAN GO. !!!!!!!!!!!!
06-02-2021, 10:10 AM | #8 |
Hi Ron, thanks for sharing your video. Good luck out there. Howard.
06-02-2021, 03:02 PM | #9 |
Hey Tim the numbers are up from last year so overall I'm happy.
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
06-03-2021, 07:13 AM | #10 |
06-03-2021, 08:00 AM | #11 |
Thanks for sharing Ronnie . . . looks like you're ready to go EARLY - a great position to be in. Best of luck, go fast, be safe and set some records!
Question: What transmission are you running in it? |
06-03-2021, 08:32 AM | #12 |
Be Safe ! !
Paul |
06-03-2021, 04:32 PM | #13 |
Are you going to be able to provide daily updates from the track?
06-03-2021, 08:52 PM | #14 | |
There's usually a good post underway on the HAMB with daily results. I'm going to be to busy trying to get the record bumped to get results out on the Barn daily. Besides our Rear Engine Modified Roadster were also running a 34 roadster with a supercharged ARDUN my son will be driving the 34 and if things work out a second driver for the 34 will give it a try as well. Running the second car will pretty much take up any spare time I might have for posting. We might be crazy trying to run two cars but heck you gotta be a little crazy to do this fun stuff anyway. Good thing its called Speed WEEK we may need all of it this time. Ronnieroadster
06-03-2021, 09:16 PM | #15 | |
The station in the pits also broadcasts on the internet. Frequencies and URL's are announced well before the meet. |
06-04-2021, 01:40 AM | #16 |
I gotta ask, can you give us the RW Hp and the engine rpm?
Frank '35 Ford Model 51 '48 Ford F3 '54 Ford Tudor Mainline |
06-04-2021, 11:05 AM | #17 |
Fantastic! Keep up the good work!
"Sometimes he would accuse chestnuts of being lazy, the sort of general malaise that only the genius possess and the insane lament." |
06-04-2021, 08:09 PM | #18 |
There are some things I wont give away. To get a stock block flathead to put out the power needed to run 200 MPH burning gasoline has taken my son and I a whole lot of time {years} experimenting until we found the sweet spot for reliability and the power needed. So I hope you would understand for now I will keep some stuff secret.
Ronnieroadster
06-08-2021, 11:17 AM | #19 |
Awesome Ronnie, best of luck this year!
06-08-2021, 06:47 PM | #20 |
Thread Tools | |
Display Modes | |
