Old 08-01-2014, 09:29 AM   #1
ersatz
ersatz's Avatar
Default Need 3 Speed Gear Shift Rebuilt....
I have a spare 3 speed transmission for my 46 Ford PU. The tranny was rebuilt, however, the top loader gear shift needs rebuilding. When shifting to 2nd gear the handle has 2-3 inches of sloppy play to the left.
I'm in New Jersey. Can someone recommend a reputable rebuilder to me?
Thanks in advance for your help!
ersatz is offline   Reply With Quote
Old 08-01-2014, 11:55 AM   #2
supereal
supereal's Avatar
Default Re: Need 3 Speed Gear Shift Rebuilt....
Try Charlie Schwendler in Orchard Park NY. His phone is 716/662-9159. He is an old hand at transmissions.
supereal is offline   Reply With Quote
Old 08-01-2014, 12:52 PM   #3
VeryTangled
VeryTangled's Avatar
X2 on Charlie ny here on the 'Barn.
[email protected]
He did the tranny and rear in our car and my Dad thought the world of him. Treated us VERY fairly.
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 08-03-2014, 09:09 AM   #4
ersatz
ersatz's Avatar
Thank you for the referral supereal & VeryTangled! A friend & I took the tower apart and found the gear shift lever to be the problem......badly worn. Now, I need to find a Gear Shift Lever for the tranny, or have a machinist do some magic.
Would appreciate any sources to obtain a lever for a 1942-1947 Pick Up. Thanks!
Old 08-03-2014, 11:00 AM   #5
AnthonyG
AnthonyG's Avatar
Check with Cliff Tipton, Cliff Tipton <[email protected]>;
Nomad
AnthonyG is offline   Reply With Quote
Old 08-03-2014, 10:11 PM   #6
alanwoodieman
any "new" one you buy will have some wear, have a machinest weld the side of the worn linkage and then grind down, I have done a few myself, tried brazing one up and it only lasted about 4 years, the rest I have mig welded and ground down, all of them worked really good
alanwoodieman is offline   Reply With Quote
Thread Tools
Display Modes
