Old 09-01-2020, 08:13 PM   #1
Steve Plucker
Default Solid Spindle Connecting Rods (Tie Rods)
Has anybody ever run into SOLID Spindle Connecting Rods or Tie Rods which may have been used during the Model A Ford production period?
And if so...Just how did you determine it was SOLID and not a tube?
Thanks.
Pluck
Old 09-01-2020, 10:01 PM   #2
1955cj5
1955cj5's Avatar
Default Re: Solid Spindle Connecting Rods (Tie Rods)
My 29 ccpu had a solid tie rod.
Of course it may have been changed out at some point....but we've owned it since 1962.
It is worn part way through....picture attached...
Would a factory installed part be marked in any way?
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 09-02-2020, 10:47 AM   #3
katy
katy's Avatar
Ford like to put their name on as many parts as possible, so it's possible, if it's original, that it has "Ford" on it somewhere.
Old 09-02-2020, 01:14 PM   #4
1955cj5
1955cj5's Avatar
I'll go get it and clean it up and see what I find......film at 11.....
Old 09-02-2020, 02:58 PM   #5
1955cj5
1955cj5's Avatar
I was wrong.
It is not solid.
I could find no letters or numbers on it.
I'm lucky I changed it for a new solid repo replacement.
The old rod/tube is .701" in diameter, but the worn area is only .542".
I was able to easily drive a punch through what little tube remained in that worn area.
You can also see that the end is capped.
Old 09-02-2020, 08:21 PM   #6
Steve Plucker
Originally Posted by 1955cj5 View Post
I was wrong.
It is not solid.
Not "capped" but about a 3 inch plug.
Pluck
