04-06-2013, 01:55 PM | #1 |
Compression PSI
So I finally put the Compression Gauge with the custom fitting for Model A sparkplugs holes to use.
All 4 cylinders hit exactly 60 psi. Is this within Specification?? Not to put TOO fine a point on it, I've NEVER had any engine match compression exactly between 4,6, or 8 cylinders, but I want to really know if it should be higher, and while 60 psi is good, do I have a valve problem and as such I should be seeing something higher? In the mean time I'm NOT MESSING WITH IT because the engine runs fine!! Worried for nothing??
20 years ago we had Johnny Cash, Steve Jobs, and Bob Hope. Now we have no Cash, no Jobs, and no Hope...please don't let Kevin Bacon die! |
04-06-2013, 02:58 PM | #2 |
Re: Compression PSI
How did you do the test? If you didn't prop the throttle open, you could probably get a higher reading with it open. Let the engine turn 4 or more good revs and see what you get.
http://www.model-a-ford-4bangers.com/ |
04-06-2013, 03:26 PM | #3 |
Re: Compression PSI
Doesn't the engine run good ? 60# sounds just fine to me. The key is to take note of the very first pulse of the gauge and the last after the engine has spun over about half dozen times. They should all be within about 10% of one another.
04-06-2013, 05:17 PM | #4 |
Re: Compression PSI
Pulled 4 plugs. Turned 4 full turns (amazing to reach across an engine and push on a metal rod that fires the starter.
1st turn = 60 psi. 6th or more = 60 psi. Throttle was closed, coil disconnected, gas gauge shut down, Tilly bowl dry. This all came about from a Samba guy (VW Bus) who had 3 of 4 exhaust valves that looked like the back end of a Wookie the night after some Romulan Ale, so he suggested a vac test. I really don't want to pay for a leakdown test, and the car runs fine - so I dont' want to mess TOO much with it, and 60 psi sounds good, but "The Book Of Les" does not give a figure. Is there a better way to do this to get better answers? I really don't want to pull the valves/cover, etc. cause then the problems will mount and I'll wish I'd just left a well running car ALONE!!
04-06-2013, 08:08 PM | #5 | |
Re: Compression PSI
Kidding aside, my engine has 50-50-50-50 and has good power. It's well worn and a bit noisy, but I'll just keep going with it until I rebuild my original engine with counterweights. You're doing fine with 60 lbs. and I'd just keep using it until it has a real problem. |
04-06-2013, 08:41 PM | #6 | |
Re: Compression PSI
04-13-2013, 06:31 PM | #7 |
Re: Compression PSI
Why?
I am about to do a compression test and don't understand why the throttle must be wide open. And do I shut the fuel valve off first? If not, am I not just introducing a lot of raw fuel into the cylinders and diluting the oil? And why must the engine be hot? |
04-13-2013, 06:52 PM | #8 | |
Re: Compression PSI
If the throttle is wide open, cranking will not provide sufficient flow velocity through the carb venturi to draw fuel. With the throttle closed, cranking does draw raw fuel from the idle port. The idle port delivers nothing when the butterfly is open. Hot gives you a better indication of how the rings perform when heated and expanded to their normal operating position. They almost always leak more when cold. Since you run hot, that's the compression reading that matters most. |
04-22-2013, 04:30 PM | #9 |
Re: Compression PSI
Car runs fine? Do not fix what is not broke. John
04-24-2013, 12:49 AM | #10 |
Re: Compression PSI
Man after my own heart, Jifffy! Dog here, bet you got a Dog!
If your Model A's runnin' great & makin' 'em Good sounds, why you even messin' with it? If there was a specified, proper compression spec, how do you know if your gage is correct? If yo' head's been surfaced 3 times or it's bored .100" over, like Vermin, a spec. # don't mean much. Like why do folks always "reading" their plugs when car's runnin' PRIMO? Ol' Glen's about wore out his threads takin' plugs out to "READ" them, when it's runnin' GOOD! I can read our plugs in the car, it reads, "CHAMPION-C16C" Buster T.
04-06-2013, 05:31 PM | #11 |
Re: Compression PSI
Sounds as though the only bit to change is to try it with the throttle wide open - lets more air into the intake manifold. Since your 1st and 6th turn readings are identical, that is fine.
Was there a reason for doing the test - other than that ugly sounding Wookie stuff, or idle curiousity? |
04-06-2013, 06:04 PM | #12 |
Re: Compression PSI
Idle, and I bought a custom Vac gauge on EPay.
04-06-2013, 05:36 PM | #13 |
Re: Compression PSI
According to the specs posted on Mac's Auto Parts page:
Compression Pressure: A6050A head, 76 PSI A6050B head, 110 PSI B6050 head, 90 PSI We never worried too much about the compression to new specs. Of course I do not have much experience with these engines, I am thinking from working on an inline 6 w/overhead valves. The key is cylinder to cylinder being within 10 or 15 % of each other, and it seems you are right on the mark there.
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain. It is the very things that we think we know, that keep us from learning what we should know.- Unknown |
04-06-2013, 07:16 PM | #14 |
Re: Compression PSI
Wow roccaas, that is one fine looking car in your avatar.
04-06-2013, 10:07 PM | #15 |
Re: Compression PSI
Not mine. GT Alumni Association 'Reck, 31(?) Deluxe Roadster pictured in front of Atlanta History Museum. Not the "Real" 'Reck - '30 Sports Coupe, but I've always likes the pic.
04-06-2013, 08:49 PM | #16 |
Re: Compression PSI
While I agree with James that proper way to test compression is with the throttle open, I would say that your numbers of 60-60-60-60 are very good for a stock A with a stock head.
I suspect that if you did the test again with the engine hot and with the throttle open, you would probable get slightly higher readings. But I would not bother. These are good. And you said it yourself: the car runs fine. Just go drive it!
04-13-2013, 07:38 PM | #17 |
Re: Compression PSI
Thanks for your very clear and helpful answers
My compression tester has a rubber nozzle to insert into the spark plug hole but I feel it would be much better to screw something in there to get a more airtight fit. One of the above posts mentioned an adapter for that purpose. Where can I get one from? Last edited by Mad Mac; 04-13-2013 at 07:42 PM. Reason: Further thoughts |
04-13-2013, 07:58 PM | #18 |
Re: Compression PSI
Most suppliers have them.... but you need the type of tester that has a flexable hose that threads into a modern type plug hole to thread into the adapter.....
http://www.snydersantiqueauto.com/3799 Like this
Wanted: Simmons Super Power Head Craig Likon 1931 150B |
04-13-2013, 08:02 PM | #19 |
Re: Compression PSI
"Where can I get one from?" .......from any of the suppliers listed on the front page of this forum at the top, Websites.....
04-13-2013, 09:09 PM | #20 |
Re: Compression PSI
Thanks,
Will follow that up. |
