Old 09-15-2020, 08:35 PM   #1
Marcus
Marcus's Avatar
Default '29 No-Start Surprise
Ol' Clyde, 29 CCPU, parked for several months (Sta-Bil in the system), battery on Tender. Spun freely and strong, but no start. So, on a whim and before checking the usual suspects, I had a friend operate the starter while I quickly hand-choked the carb by placing my hand over the carb intake (brand new rebuild, by the way) - Ol' Clyde fired immediately and ran perfectly....... Drove around with no problems, returned home, put him in the garage, and tried to start: nope! (Don't have my friend right now available to assist), so what do you think, Fordbarn gurus??
WARM REGARDS, MARCUS
Marcus is offline   Reply With Quote
Old 09-15-2020, 10:22 PM   #2
CWPASADENA
CWPASADENA's Avatar
Default Re: '29 No-Start Surprise
Choke butter fly may not be closing all the way when you pull up on the choke. It has to close all the way or you will not get enough "suck" to pull gasoline up into the intake.
My opinion,
Chris W.
CWPASADENA is offline   Reply With Quote
Old 09-16-2020, 09:09 AM   #3
Big hammer
I think Ol'Clyde is a contrary old man who needs some adjustment! Or if you want to start him buy choking him with your hand, raise the hood choke with your left hand reach over and push down on the starter rod your self. If your carefull Ol'Clyde won't bite you !
get a bigger hammer tap done
Old 09-17-2020, 09:31 AM   #4
supergnat
supergnat's Avatar
If you try to start Clyde yourself be sure he is in neutral and apply the parking bake or he may try to run you over.
supergnat is offline   Reply With Quote
