05-02-2020, 07:52 AM | #1 |
'40 rear backing plate E brake
Can you buy the E brake tube that the E brake cable goes through on the rear backing plate somewhere ? Prefer NOS or good used originals. Thank you Fordbarners.
05-02-2020, 08:04 AM | #2 | |
Re: '40 rear backing plate E brake
However, you can purchase the exact this wall tube from McMaster-Carr (quite reasonable) and make a coupe rather easily.
05-02-2020, 08:11 AM | #3 |
Don't think replacement tubes were provided by Ford.
If originals are needed; lots of backing plates with good tubes are still around. Other options. Clings sells new replacements. Tubes are easy to make out of 1/2" tube. |
05-02-2020, 08:36 AM | #4 |
MT Products includes new E Brake tubes with their rear backing plates.
Perhaps they would sell you a pair separate from the backing plate without having to buy the backing plate. You could then cut them to fit. Worth a try. http://www.mtcarproducts.com/productsgrid.html |
05-02-2020, 08:39 AM | #5 |
Thank you. I figured I could make them from tube, and weld them in, but the "flare" at the end to retain the rubber seal might by a challenge.
05-02-2020, 09:35 AM | #6 |
05-02-2020, 09:38 AM | #7 |
boot
05-02-2020, 09:54 AM | #8 |
Looks like Rich hit a home run. Do it his way.
05-02-2020, 09:16 PM | #9 |
The e-brake cable tube is available from MT Products (http://www.bolingbrothers.com/).
They were also listed in Bob Drake's catalog not too long ago.
Those who do not move do not die, but are they not already dead? |
